@rubber_jonnie
This can be a good alternative to tapes or making new tapes
https://www.trs-80.com/wordpress/conver ... utilities/
Tom
Woo hoo - Collection Completed!! TRS-80 inbound
Tomswork
Re: Woo hoo - Collection Completed!! TRS-80 inbound
Thanks, I'll take a look at that. That particular site is a goldmine of information, I referred to it quite a lot during the initial fix.Tomswork wrote: 22 Oct 2022 21:57 @rubber_jonnie
Tom
What I'd really like to get my hands on is an SD adapter, there are some I've seen out there, but they seem quite costly. Even some sort of simple floppy adapter would be handy as I could use a Gotek with it.
Ok, so I have been trying to find some sort of HDD solution for the TRS-80 model 1, and I finally found these:
FreHD site
FreHD - designers site
I now have myself the Gerbers for the PCB and they upload fine to JLPCB, so I think I'll be dropping an order very soon, but there does seem to be ab additional board that I can't find anywhere that seems to be the interface from the TRS to the SD adapter.
I guess it's one step at a time!!
FreHD site
Tomswork
Yes the frehd works well and you can print a 3d bracket for a old 5.25 case it also will hold a gotek
Tom
@rubber_jonnie
Tom
@rubber_jonnie
Awesome, thanks again for your input sir.Tomswork wrote: 24 Apr 2023 20:38 Yes the frehd works well and you can print a 3d bracket for a old 5.25 case it also will hold a gotek
Tom
@rubber_jonnie
BTW, I have the FreHD board gerbers and will likely order 5, but on this site the image shows some sort of additional interface board:
And it seems to connect the TRS to the FreHD, but there don't seem to be any gerbers for that. Any ideas?
Tomswork
Frehd on a model 1 needs the extra card for buffers and some line placement changes on the 3 and 4 they are not required
Tom
@rubber_jonnie
Tom
@rubber_jonnie
I figured it was something like buffers/logic, but is there a design out there for one I could build?Tomswork wrote: 24 Apr 2023 23:21 Frehd on a model 1 needs the extra card for buffers and some line placement changes on the 3 and 4 they are not required
Tom
@rubber_jonnie
Tomswork
I'm not sure its comes from Australia you can always contact them i will look up the contact info and post it
ianm@trs-80.com
http://ianmav.customer.netspace.net.au/clearlysuperior/
Tom @rubber_jonnie
ianm@trs-80.com
Tom @rubber_jonnie
That interface board is a “Quinnterface” which doesn’t seem to be open source. It adds address decode, RAM and interface logic for TRS-80 Model I. There are other boards used for the other TRS-80s.
Thanks Tom. Mr Usher has ID'd it a a Quinnterface, and it's not apparently open source, but it at least gives me a starting point.Tomswork wrote: 25 Apr 2023 02:40 I'm not sure its comes from Australia you can always contact them i will look up the contact info and post it
ianm@trs-80.com
Tom @rubber_jonnie
EDIT: Tom, having looked I see the Quinnterface on the page you linked to, thanks.
Users browsing this forum: ClaudeBot and 19 guests
