Isn't PUPLA some sort of weird bus buffer board ?HigashiJun wrote: 10 Jan 2023 11:17 My PAK (FPU fitted) was rock stable at 40 Mhz in my Mega ST, and there was no need for a PUPLA either.
PAK 68/3 in STE
Re: PAK 68/3 in STE
Re: PAK 68/3 in STE
Yes, it is supposed to help with stability issues.exxos wrote: 10 Jan 2023 11:25Isn't PUPLA some sort of weird bus buffer board ?HigashiJun wrote: 10 Jan 2023 11:17 My PAK (FPU fitted) was rock stable at 40 Mhz in my Mega ST, and there was no need for a PUPLA either.
I will try with the PUSTE, specially made for the STE series, to see what happens.
Re: PAK 68/3 in STE
Plus these days we have a very effective soft-FPU, thanks to Anders:exxos wrote: 09 Jan 2023 22:01 I think after all the troubles @Badwolf had with the FPU, I don't think it is worth all the hassle.
https://github.com/agranlund/tftools/bl ... /fpemu.prg
:thumbup:
Re: PAK 68/3 in STE
Did that ever get finished for official release ? It should be put in the software essentials section as it would be useful to keep it handy there.
Re: PAK 68/3 in STE
Good to know that.Badwolf wrote: 10 Jan 2023 20:02Plus these days we have a very effective soft-FPU, thanks to Anders:exxos wrote: 09 Jan 2023 22:01 I think after all the troubles @Badwolf had with the FPU, I don't think it is worth all the hassle.
:thumbup:
Re: PAK 68/3 in STE
Tried yesterday my PAK68 with its original PUSTE only to discover a white screen at boot-up...
No doubts here about the culprit: the Winslow socket pins are not making contact with the CPU socket when inserted.
If you look carefully, you will notice that the pins are bent inwards.
As i didn't want to tinker with the PUSTE anymore, I decided to build exxos' DIP adapter (as two sets were biding their time in my spare parts box) and compare its behaviour with Badwolf's one.
The result is:
No more memory errors nor freezes or reboots at startup.
Ultrasatan and FDD doesn't work though, but I didn't tried with PUPLA/2 yet.
I didn't revert to original SILs and still use exxos' recommended values.
Have to investigate a bit further to see if there's a way to make Badwolf's adapter work with my PAK.
The result is:
Darklord
Re: PAK 68/3 in STE
Excellent progress. :)
Re: PAK 68/3 in STE
Tried the last setup with the PUPLA/2 and had issues as previously (memory errors and freezes) and there was no way to get to the desktop.
Guess there's too much buffers in now: exxos' adapter buffers and PUPLA/2 buffers.
TheNameOfTheGame
Re: PAK 68/3 in STE
Nice work!
