- first, with following partitions - C, D, E
- second one with C, H and I
How can I change one of Cs to be able to mount all partitions from both disk? Is there a any program for that?
1) Which driver are you using?arti040 wrote: 26 Sep 2022 20:03 I've searched for similar topic but have not found anything useful. I got two disk connected:
This is exactly what I'm trying to do. I got Atari STe with Ultrasatan. Problem is, there are two C: partitions on two SD cards so I'm not able to get access to both of them because they are in conflict. If I boot from first card, I see C: from the first one and from second card - accordingly. So, I'm looking for a way to... ekhm, change the letters assigned to those partitions? This was my first guess, basing on experience from other platforms ;-)When you then boot, the partitions shouldn't show on the desktop and you can then select one of the FDD icons on the desktop and the install disk drive option will then be live in the Options menu. You should then be able to add each partition individually into a single desktop.inf/newdesk.inf that is in the root of the boot partition.
What I would suggest you do is to locate the desktop.inf or newdesk.inf file (Later versions of TOS use newdesk) and move them to a directory so they aren't on the root of either drive.
