Received my engineering sample courtesy of @Badwolf :D
Not much to look at here.. Frankly too lazy to remove the CPU again and spend the next five hours refitting it just to take an image :lol:
"out of the box" first run with EMUTOS:
There does seem to be a odd "reset" problem somewhere along the line. In that sometimes you have to press the reset button several times to get it to boot. I do not think it is the H5 as it works fine with the CPU directly on the motherboard.
But otherwise so far so good :dualthumbup:
DSTB1 exxos first tests & experimental firmware.
Re: DSTB1 exxos first tests.
I love it when a plan comes together. :thumbup: (need a cigar emoji :P )
If you can swing TOS2.06 decoding, ALTROM time! :twisted:
PS: incidentally, pretty trivial to put a 2.06 decoder on one of the test points, now I think about it.
Next job then ;)Badwolf wrote: 22 Apr 2022 15:29 PS: incidentally, pretty trivial to put a 2.06 decoder on one of the test points, now I think about it.
Easy to hookup on a H5 :)
Actually, just noticed: there’s no AltRAM in that benchmark. EmuTOS ought to pick it up automatically, but I guess it’s not in the 192k version.
PRG EmuTOS should work, though, and get you much better figures.
*cough* Then, of course, FrontBench will look good. :mrgreen:
It doesn't pick it up no.Badwolf wrote: 22 Apr 2022 16:18 Actually, just noticed: there’s no AltRAM in that benchmark. EmuTOS ought to pick it up automatically, but I guess it’s not in the 192k version.
Not tried the PRG yet..
Ah, ok, sure. Wasn't clear. I don't think the 192k ROM version supports AltRAM at all.
PRG version found 8MB..
Testing GB6.. I think it passed all tests but crashed on the final alt-ram test...
Thing something has slowly died because it crashed while loading the benchmark reference file just.I am not sure how good the CPU is though..
Quick retest with a fan blowing on the thing this time...
