Mac Classic - will it ever run again!!
Re: Mac Classic - will it ever run again!!
Gosh those are a blast from the past. I guess it depends what they are across ? I know the ones I had were mostly 160v but thinner that that one. Though some rated AC or DC voltage. I forget which way it was, but it was like 630VAC or 315VDC kinda thing. I'll try and see what mine say when I get home. I think they were made by Phillips ? Can't exactly remember now.
That looks a bit like a dipped, non-RIFA X2 cap.
Looking at evilbay https://www.ebay.co.uk/itm/Philips-MKT3 ... ect=mobile
250V then the "dot" so yours I assume is 63v like you thought.
Definitely non RIFA, though this board did have RIFAs that were on the verge of releasing the smoke and I replaced those when I first started looking at the analog board. CP25 & CP27, so part of that left hand PSU circuit.
Hmm, yes, that would make sense.exxos wrote: 27 Dec 2021 17:02 Looking at evilbay https://www.ebay.co.uk/itm/Philips-MKT3 ... ect=mobile
Bloody annoying all these different methods of identifying capacitors!
Tomswork
I agree with the capacitors marking nightmare and the apple's love of y and x class capacitors in the macintosh line
Tom
Tom
Tomswork
@rubber_jonnie
Have you looked at the opto coupler qp1 it may have a thermal problem
Tom
Tom
I am waiting for replacement optos to arrive. I did order some, but was sent surface mount in error rather than the DIP packages needed. New ones are on the way, there isn't really much left to replace.Tomswork wrote: 03 Jan 2022 06:56 @rubber_jonnie
Tom
I've replaced the TDA4605 and recapped the entire board with a few exceptions like the small ceramics, so the opto is really the last main part of the PSU section to be replaced.
It's so annoying that I have CNY17s that simply won't physically fit. Parts are due Wednesday. I'll replace in the evening if they arrive on time.
If the problem persists after I replace that, I will have to start looking at the other components around the TDA and CNY, and I think I should consider replacing QP2, which is potentially common to both the 5v & 12v lines.
EDIT: IRF-BC40 replacement for QP2 on order.
Woo hoo, my CNY17s arrived this morning, so I will drop one in tonight, see if that helps!
Fingers crossed that it helps. At this rate you'll have a new analogue board effectively.
