People not getting web store emails
derkom
Re: People not getting web store emails
Post by derkom »
Badwolf wrote: 06 May 2021 19:49 To be fair, that alert was triggered by 12.101.4.84.rev.sfr.net rather than exxoshost.co.uk, which it became later.
Ah, I somehow missed that bit. Yes, that is quite generic then. :)
derkom wrote: 06 May 2021 19:57
that IP is nothing to do with my server..
WiseGreasyBastard
Post by WiseGreasyBastard »
Once you have DKIM running along with your existing SPF, set up DMARC and have your initial TXT record set to reporting to make sure you've not screwed anything up. Then move to p=reject to get hosts to reject emails from hosts that don't match your configuration.
Start with
v=DMARC1; p=none; pct=100; rua=mailto:dmarc@exxoshost.co.uk
Once you're happy with the setup and the reports look ok switch to
v=DMARC1; p=reject; pct=100; rua=mailto:dmarc@exxoshost.co.uk
When you are at p=reject the larger hosts will reject anything that doesn't match your published record and send you an xml report showing what they rejected along with the host and domain details for the rejected email.
The report will look something like this
<?xml version="1.0" encoding="UTF-8" ?>
<feedback>
  <report_metadata>
    <org_name>google.com</org_name>
    <email>noreply-dmarc-support@google.com</email>
    <extra_contact_info>https://support.google.com/a/answer/2466580</extra_contact_info>
    <report_id>99999191973372388545</report_id>
    <date_range>
      <begin>9999972800</begin>
      <end>9999959199</end>
    </date_range>
  </report_metadata>
  <policy_published>
    <domain>exxoshost.co.uk</domain>
    <adkim>r</adkim>
    <aspf>r</aspf>
    <p>reject</p>
    <sp>reject</sp>
    <pct>100</pct>
  </policy_published>
  <record>
    <row>
      <source_ip>188.138.88.18</source_ip>
      <count>1</count>
      <policy_evaluated>
        <disposition>reject</disposition>
        <dkim>fail</dkim>
        <spf>fail</spf>
      </policy_evaluated>
    </row>
    <identifiers>
      <header_from>exxoshost.co.uk</header_from>
    </identifiers>
    <auth_results>
      <spf>
        <domain>jbzvw21fvrr8v1r.igllakwjvqh.languagelevels.eu.com</domain>
        <result>pass</result>
      </spf>
    </auth_results>
  </record>
</feedback>
AGAIN exxoshost.co.uk is blocked by Cloudflare :cussing: :cussing: :cussing:
I am not removing myself from the list for like 50th time it is just pointless. Hopefully problems will be less when the new server goes live. But I want to phase out emails altogether as mentioned previously.
Just gets incredibly frustrating and annoying to spend time sending off to companies for quotations which I have previously used before, owing to have half emails bounce back because of cloudflare blocked me again. God knows how many companies out there are losing business because they are blocking legitimate emails :cussing:
As I said before, if any one out there uses these cloudflare spam filters then you will likely never get any emails on myself or stripe. Of course it is not so simple when ISPs sneak this service in and a lot of people probably don't even know it is even there :roll:
Darklord
Post by Darklord »
Just recently my e-mails were also blocked (from here in the US) but my
easy fix was just to call my provider (Suddenlink.net) and ask the techs
to unblock it.
Did take about 20 mins but it worked.
Of course, then I couldn't get the Web Store to stop sending e-mails... :)
Darklord wrote: 15 Jul 2021 19:32 Of course, then I couldn't get the Web Store to stop sending e-mails... :)
I only send out 2 :lol:
Darklord
Post by Darklord »
exxos wrote: 15 Jul 2021 19:37 I only send out 2 :lol:
Yep. But I had tried a few times...I think it sent 2 for every attempt
I made... :lol:
In other words, my fault... :oops:
Bump.
Cloudflare again :roll: Cannot even browse websites without them blocking it now :roll: Cloudflare are single-handedly destroying the Internet :roll:
Sinis
Post by Sinis »
Hello,
I'm not sure to write in the right post but you'll move it if necessary.
I am unable to find my orders. The mail is ok, the token allowed me to verify the mail, and the mail is the same I used for all my orders.
Unfortunately :
I'm sorry to disturb you with that but I have to plan things about christmas (as everybody :)) and try to know when the order will be shipped.
Thank you
