Yeah. That's not working.
Maybe it will magically start working in a few hours time :shrug:
sudo opendkim-testkey -d exxoshost.co.uk -s default -vvv
opendkim-testkey: using default configfile /etc/opendkim.conf
opendkim-testkey: checking key 'default._domainkey.exxoshost.co.uk'
opendkim-testkey: key not secure
opendkim-testkey: key OK
If you see Key not secure in the command output, don’t panic. This is because DNSSEC isn’t enabled on your domain name. DNSSEC is a security standard for secure DNS query. Most domain names haven’t enabled DNSSEC.
host -t any default._domainkey.exxoshost.co.uk
default._domainkey.exxoshost.co.uk descriptive text "v=DKIM1\; k=rsa\; p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAklxL/jc94pBcmiBhJjsJG5SEPa0MQUAClcl/pb6/5G1DqSqCb4VB0RdkZIBAkmvEkw1QU........
exxos wrote: 06 May 2021 17:42 oh...
host -t any default._domainkey.exxoshost.co.uk default._domainkey.exxoshost.co.uk descriptive text "v=DKIM1\; k=rsa\; p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAklxL/jc94pBcmiBhJjsJG5SEPa0MQUAClcl/pb6/5G1DqSqCb4VB0RdkZIBAkmvEkw1QU........
I think this is sound advice, and also I think a big clue to the real cause of the problem lies in the example they gave of "generic" hostnames:xyzzy76 wrote: 06 May 2021 18:37 I noticed you're using the bare domain for your mail server (exxoshost.co.uk)
Try using mail.exxoshost.co.uk as your mail server name, and set the PTR record to this as well.
postconf -e 'myhostname = mail.exxoshost.co.uk'
ok ill change it.xyzzy76 wrote: 06 May 2021 19:20 Something like:
To be fair, that alert was triggered by 12.101.4.84.rev.sfr.net rather than exxoshost.co.uk, which it became later.derkom wrote: 06 May 2021 18:59 I bet what's happening here is they have some kind of pattern matching going on that thinks "exxoshost.co.uk" is generic hosting provider reverse DNS, because of the string "host" existing in the domain name. Depending on how they have their regular expression setup, tacking a hostname on the front as @xyzzy76 suggests may well stop it from tripping their "generic" pattern match.
