Hi,
I have received my brand new PSU and it looks great.
I'm going to have a go at fitting it later on, however, looking at the PSU fitting instructions here https://www.exxosforum.co.uk/atari/last/ ... htm#PSUFIT.
I take it there is no longer a requirement to drill a hole in the metal PSU base and use the arctic silver paste as the actual component isn't there any more on the new PSU?
I got a new switch as well with it so will be removing that and fitting the new switch too. Are all the other PSU fitting instructions on that page still valid?
Cheers for everything and the PSU looks like a wonderful design.
Regards,
Brett
Exxos PSU 2021 edition
Re: Exxos PSU 2021 edition
The site is a bit outdated https://www.exxosforum.co.uk/forum/viewt ... f=9&t=1245
BrettRogersUK
Hi,exxos wrote: 11 Dec 2021 14:27 The site is a bit outdated https://www.exxosforum.co.uk/forum/viewt ... f=9&t=1245
Thanks for the reply. When testing it is there a requirement to use the load resistors anymore as with the old PSU?
Regards,
Brett
The load resistors are there to stop the fuse blowing. All the info is on the page I posted near the bottom.
BrettRogersUK
Ok, no worries.exxos wrote: 11 Dec 2021 14:39 The load resistors are there to stop the fuse blowing. All the info is on the page I posted near the bottom.
Thanks again!
Regards,
Brett
UnderTheRain
Does your PSU fit under the standard shielding?
Thanks
Brian
Thanks
Brian
