Tony's Falcon service blog (Nov 2021)
Hi guys,
Just working on Tony's Falcon.
We are doing:
  • PSU recap
  • Falcon motherboard re-cap
  • Reverse old clock patch
  • Exxos clock buffer
  • Exxos NVRAM
  • Exxos RAM board
  • Install FPU
  • Install Fast TOS 4.04
  • Disable wait states
  • Install Openflops drive
Link to motherboard high res photos
Just checking to make sure it's working as expected to begin with
There are two types of NVRAM on a falcon, the ST branded NVRAM is easier to remove because its legs are visible on the topside, so much easier to use solder wick and the heat gun
A quick clean up with solder wick
Socket installed
NVRAM installed
Fast TOS 4.04 installed so we can later disable the motherboards wait states
Re: Tony's Falcon service blog (Nov 2021)
Clock patch removal / fix / install Exxos version. This resistor is the old ct60 'patch' and is very obsolete/bad
Removing the resistor (carefully) reveals the trace has just disintegrated
Some fine patch-work to recreate the trace
Remove all these resistors to install the Exxos patch
Voila
Looking good, Steve!
Freadus
Post by Freadus »
That's a very nice repair on the SDMA, extremely neat indeed!
@Steve Don't forget there is a SMT resistor to go one the SDMA end..
exxos wrote: 08 Nov 2021 22:17 @Steve Don't forget there is a SMT resistor to go one the SDMA end..
I thought we only added that if required, I was going to do some tests to see if it was needed (I've only had to add it to one falcon so far)
Steve wrote: 09 Nov 2021 09:07 I thought we only added that if required, I was going to do some tests to see if it was needed (I've only had to add it to one falcon so far)
It's listed on the install page and I don't mention it's optional. Even if it works for some weeks, doesn't mean it always will. Ambient temperature could change enough to cause things to malfunction.
Ah okay then. So we should be adding that all the time now, no problems.
@exxos Job done boss :2k2:
Steve wrote: 09 Nov 2021 13:52 @exxos Job done boss :2k2:
:bravo:
You may want to put some hot snot glue over it because soldering a resistor to a small track is not very mechanically robust.
Users browsing this forum: apple [bot], britelite, ClaudeBot, jmorden, Steve, xyzzy76 and 9 guests
