STe service blog / CA300779-001 Rev 5.1
Hi guys,
Just doing some servicing on a customers STe, here is my work on it...
Board images here
* Clean disk drive
* Apply motherboard bus resistor fixes
* Replace a few important capacitors, like reset circuit
* Add STe ghosting fix capacitor
* Replace mouse/joystick port
* clean/resolder video port
* General machine clean
The beginning...
What do we have missing here?
Bit rusty on the shield
Floppy needs a good clean and service!
Time for a thorough clean
Let's replace the drive lube
Let's also re-cap the floppy
Shame, after all that the floppy is still having issues!
The floppy heads are physically touching/scratching the disk, you can see the black mark worn on the head. The floppy drive is TOAST. So we are going to go for a FlashFloppy instead!
Re: STe service blog / CA300779-001 Rev 5.1
Time to re-cap the PSU! It is a DSP-508a
After the recap, looking good!
Time to test the voltage output under load!
Time to do some work on the motherboard, first the reset circuit and 470uf capacitor
New 4700uf capacitor
Now time to swap out the 10k SILs for 2.2k
Let's add the video ghosting fix while we're here
Time for some keyboard work
Quite a bit of grunge to clean
Looks like the port area has a missing pad and broken trace
Guess who put it back together, all 30 or so screws, then realised he forgot to reflow the solder on the mouse port... Well, it's done now.
Let's give the keyboard and casing a good wash
Board nice and clean now
Those rubber feet look melted! Let's replace them
After everything I've done so far does everything still work I wonder? Let's do a quick test :)
New HC type CPU
New Hotel drive
@Steve what are you using for replacement feet?
repair looks good btw.
What's going on with that FDD? I've never seen one with all the motor coils exposed like that, looks like it's missing the rotor or something.
rubber_jonnie wrote: 14 Oct 2021 15:23 What's going on with that FDD? I've never seen one with all the motor coils exposed like that, looks like it's missing the rotor or something.
They're not normally exposed, I was just replacing the capacitor which needed the cover taking off.
Steve wrote: 14 Oct 2021 15:24
I get that, I'm used to seeing this:
With the coils under the rotor (Silver disc) so that looks really strange to me. How is the spindle driven?
By cover did you mean the FDD case or the silver disk?
I'm just curious is all :)
@rubber_jonnie Check this out, same drive:
https://www.exxosforum.co.uk/atari/last/ ... /index.htm
Users browsing this forum: apple [bot], ClaudeBot and 13 guests
