STe service blog / CA300779-001 Rev 5.1
Hi guys,
Just doing some servicing on a customers STe, here is my work on it...
Board images here
* Clean disk drive
* Apply motherboard bus resistor fixes
* Replace a few important capacitors, like reset circuit
* Add STe ghosting fix capacitor
* Replace mouse/joystick port
* clean/resolder video port
* General machine clean
The beginning...
1. begin.jpg (366.87 KiB) Viewed 3659 times
What do we have missing here?
2. oops what is missing.jpg (238.35 KiB) Viewed 3659 times
Bit rusty on the shield
3. rusty shield.jpg (226.46 KiB) Viewed 3659 times
Floppy needs a good clean and service!
4. dirty floppy.jpg (435.48 KiB) Viewed 3659 times
Time for a thorough clean
8. cleaning floppy.jpg (489.56 KiB) Viewed 3659 times
9. clean floppy.jpg (375.47 KiB) Viewed 3659 times
Let's replace the drive lube
5. old lube.jpg (436.33 KiB) Viewed 3659 times
10. new lube.jpg (379.02 KiB) Viewed 3659 times
Let's also re-cap the floppy
6. recap floppy 1.jpg (455.28 KiB) Viewed 3659 times
7. recap floppy 2.jpg (430.39 KiB) Viewed 3659 times
12. recap floppy motor.jpg (439.46 KiB) Viewed 3659 times
Shame, after all that the floppy is still having issues!
11. floppy still bad.jpg (235.64 KiB) Viewed 3659 times
The floppy heads are physically touching/scratching the disk, you can see the black mark worn on the head. The floppy drive is TOAST. So we are going to go for a FlashFloppy instead!
13. chewing disks.jpg (280.69 KiB) Viewed 3659 times
Re: STe service blog / CA300779-001 Rev 5.1
Time to re-cap the PSU! It is a DSP-508a
18. psu before recap.jpg (300.89 KiB) Viewed 3657 times
After the recap, looking good!
19. psu after recap.jpg (295.72 KiB) Viewed 3657 times
Time to test the voltage output under load!
21. test 5v.jpg (315.78 KiB) Viewed 3657 times
20. test 12v.jpg (320.8 KiB) Viewed 3657 times
Time to do some work on the motherboard, first the reset circuit and 470uf capacitor
15. re-cap reset circuit and 470uf.jpg (483.28 KiB) Viewed 3656 times
New 4700uf capacitor
Now time to swap out the 10k SILs for 2.2k
16. old sils gone.jpg (479.69 KiB) Viewed 3656 times
17. new sils in.jpg (431.79 KiB) Viewed 3656 times
Let's add the video ghosting fix while we're here
14. video ghosting fix.jpg (435.9 KiB) Viewed 3656 times
Time for some keyboard work
22. time to fix keyboard.jpg (375.08 KiB) Viewed 3649 times
Quite a bit of grunge to clean
23. a bit grungy.jpg (270.43 KiB) Viewed 3649 times
24. more grunge.jpg (345.26 KiB) Viewed 3649 times
Looks like the port area has a missing pad and broken trace
25. missing pcb pad trace.jpg (343.14 KiB) Viewed 3649 times
28. new port soldered and trace patched.jpg (399.44 KiB) Viewed 3649 times
Guess who put it back together, all 30 or so screws, then realised he forgot to reflow the solder on the mouse port... Well, it's done now.
30. new port.jpg (329.93 KiB) Viewed 3649 times
Let's give the keyboard and casing a good wash
26. time for a wash.jpg (393.77 KiB) Viewed 3649 times
27. wash case.jpg (455.7 KiB) Viewed 3649 times
Board nice and clean now
29. clean board.jpg (410.01 KiB) Viewed 3649 times
Those rubber feet look melted! Let's replace them
31. old feet.jpg (224.84 KiB) Viewed 3649 times
32. new feet.jpg (256.31 KiB) Viewed 3649 times
After everything I've done so far does everything still work I wonder? Let's do a quick test :)
33. does it still work.jpg (364.79 KiB) Viewed 3649 times
New HC type CPU
New Hotel drive
@Steve what are you using for replacement feet?
repair looks good btw.
What's going on with that FDD? I've never seen one with all the motor coils exposed like that, looks like it's missing the rotor or something.
rubber_jonnie wrote: Thu Oct 14, 2021 3:23 pm What's going on with that FDD? I've never seen one with all the motor coils exposed like that, looks like it's missing the rotor or something.
They're not normally exposed, I was just replacing the capacitor which needed the cover taking off.
Steve wrote: Thu Oct 14, 2021 3:24 pm
I get that, I'm used to seeing this:
With the coils under the rotor (Silver disc) so that looks really strange to me. How is the spindle driven?
By cover did you mean the FDD case or the silver disk?
I'm just curious is all :)
@rubber_jonnie Check this out, same drive:
https://www.exxosforum.co.uk/atari/last/ ... /index.htm
