TF1230 Beta Interest (Open Source)
- Admin sponsor
Re: TF1230 Beta Interest (Open Source)
My A1200 1D4 gets stuck during boot..... Reading some address like 22000.. I am betting there is a bad rom address line or something.
alenppc
- Moderator Team
Now we all have very consistent results... :)supaduper wrote: 26 Aug 2021 14:42 For continuity goose sent me a board and built it with the same components as the Tf330 and the results are in:)...both my 1D4 1200s give a mustard screen, but the 2b A1200 no probs runs like a good un` , thought I would just throw these resullts into the mix, but a awesome little board steve :)
All of my A1200s are 1D4 so the board doesn't work on any of them.
Lemaru
I've just opened mine up and found its a 1b. Haven't seen anyone post any results from this one neither, so may grab one to give it a test.
Higgy
Make sure your 1B edge connector has a bevel/chamfer. Both mine didn't and although it is ok with old style accelerators the edge connector used on new cards will get knackered!!
Get your file out :)
GadgetUK164
Received the board, socket, XTAL and regulator thanks go0se!
Lemaru
I didn't actually notice that. Would take a look, but just had a fight with the metal shielding resulting in blood, so put it away for today. lol. Will check it when off work next, cheers for the heads upHiggy wrote: 26 Aug 2021 17:34Make sure your 1B edge connector has a bevel/chamfer. Both mine didn't and although it is ok with old style accelerators the edge connector used on new cards will get knackered!!Lemaru wrote: 26 Aug 2021 17:05
Danoo
Tracking is indicating the PCBs from JLCPCB will turn up today, have the rest of the components ready to go, I have a 1D.1, 1D.4 and 2B to test the card on.
I noticed an alpha firmware in @terriblefire Github binaries dated 01 April 2021, is this the jed to use or is there a later version.:?: I am guessing there is a later version from reading some of the previous posts.
kulamario
Welcome
Today I got few 1200 boards but only 1D4
1D4 and kick 3.2 working without any issues on two boards
later I will check on 3.1
8 Bit Dreams
- Moderator Team
Same here - no luck on 1D4 MB & KS 3.1, both cards give yellow 🟡 screen... Will try with KS 3.2 and DiagROM later today
kulamario
I had yellow but I wiped clean connector in amiga IPA8 Bit Dreams wrote: 27 Aug 2021 18:41 Same here - no luck on 1D4 MB & KS 3.1, both cards give yellow 🟡 screen... Will try with KS 3.2 and DiagROM later today
Users browsing this forum: ClaudeBot and 164 guests
