I quite agree.
Oops, my obsession with computers from my childhood strikes again!
And it arrived today :)
The FDD controller looks very much homemade, if indeed it is an FDD controller! I need to look and see what P5 & P6 are.
EDIT - turns out they are 2K PROMS so I perhaps need to see if I can download the contents for safe keeping.
:cheer:
The big power on is tomorrow :)
Also, definitely an FDD controller :)
Let's hope for no magic smoke.
Yep, I second that!
Tomswork
Just a reminder there are rifa caps in the power supply if it has not been recapped.
:fire:
Tom
:fire:
Tom
Ok, so RIFA replacements are inbound and old ones are out.
Next up I need to pull the mainboard and check the video out connector as the signal is not great right now. I'll check the solder has no cracks and give the connector a clean up too.
I need to find a better composite cable too as the one I have can best be defined as 'poor quality'!
After that I need to source a FDD emulator and an AUX port memory card so that I can use 80 column mode.
Trying it out the other day it reminded me that BASIC commands need to be upper case, something I'd forgotten in the 40 years since I last used one!!
lilwashu
Some guys on Stardot have recently posted how to get an RGB2HDMI board working properly on a IIe which I will be doing as soon as I get hold of a board - I am used to RGB video from when I had one as a kid, and composite on a PAL machine is just awful when it switches to colour mode.rubber_jonnie wrote: 15 Aug 2021 11:18 Next up I need to pull the mainboard and check the video out connector as the signal is not great right now. I'll check the solder has no cracks and give the connector a clean up too.
I'll have a look over there, see what it says as also a member due to my BBC Bs & Electron. Also have a Mac Classic I'll be working on and trying what Adrian Black did here: https://www.youtube.com/watch?v=pvjsXbz1xlk&t=803slilwashu wrote: 15 Aug 2021 14:39Some guys on Stardot have recently posted how to get an RGB2HDMI board working properly on a IIe which I will be doing as soon as I get hold of a board - I am used to RGB video from when I had one as a kid, and composite on a PAL machine is just awful when it switches to colour mode.rubber_jonnie wrote: 15 Aug 2021 11:18 Next up I need to pull the mainboard and check the video out connector as the signal is not great right now. I'll check the solder has no cracks and give the connector a clean up too.
Users browsing this forum: ClaudeBot, Steve and 14 guests
