DaveC's H5 C1 Build
Re: DaveC's H5 C1 Build
:dualthumbup: :yay2: :cheer: :yay: :girldance:
Post by JezC »
:cheers: :bravo:
Post by JezC »
PhilC wrote: 14 Jul 2021 19:45 @JezC it depends on what you want to fit. I fitted a ds1315 clock chip, oscillator etc and will put jumpers on the flashy clock socket but just temporarily I've bridged the middle two with solder.
@PhilC ah, good to know. Might need some clarification for what is needed for the different build options.
DaveC
Post by DaveC »
PhilC wrote: 14 Jul 2021 20:56 :cheer: :cheer: :cheer: Well done. Fun but easy wasn't it :)
Yeah, was definitely less than 2 hours work. I mean the parts turned up around 1.30, mid lunch and had to pick kids up from school too.
Think the difficult part was removing the PLCC chips from donor board as they both stuck in one corner! Oh and obviously not jumping those 2 bits :roll:
DaveC
Post by DaveC »
Definitely have some sort of problem, get bombs when it tries to read a disk. Whether from boot up or desktop.
Address line issue? From the screen corruption.
@DaveC have a look at your DMA and WD1772, also try reseating your GLUE and see if this helps. The board itself is very nearly plug and play, so its likely some bad connection.
Run YAART and see if the RAM is OK.
DaveC
Post by DaveC »
YAART doesn't give any errors.
Diagnostic cart gives this for most of the floppy tests.
EB Bus Error  Access Address: 4E4E50 Program Counter: 4E4E50
EB Bus Error  Access Address: 4E4E50 Program Counter: FA0E88
Originally sound test didn't work but sounds fine after applying the audio fix.
Tried reseating most of the chips. Swapped the WD1772 as I had known working one in my STe.
Be interesting to see what @JezC gets when he tests with the cartridge!
I would re-seat / resolder the GLUE...
Return to “H5 C1 USER BUILDS”
