Booting to TOS 1.0 from floppy disk.
- Cosmic Puppet
Re: Booting to TOS 1.0 from floppy disk.
I now have a floppy disk which changes the Atari to TOS 1.0
Having disk problems so formatting from TOS 1.0 now.
I'm not suggesting you emulate, merely using Hatari to verify that the image you suggested was a ROM image and not a disk image. They are not the same and you'll never boot a TOS 1.0 ROM image like a disk.Cosmic Puppet wrote: Thu Jun 24, 2021 11:32 pm I only use emulators for DOS gaming.
I will never emulate when it comes to Atari.
Found here:
http://www.avtandil.narod.ru/tose.html
Thanks!
Also I don't believe you can boot a TOS 1.0 floppy on a machine that contains full TOS in ROM, at least not without SELTOS.
- Cosmic Puppet
- Cosmic Puppet
I know you wasn't I'm just weird.rubber_jonnie wrote: Thu Jun 24, 2021 10:42 pm I'm not suggesting you emulate, merely using Hatari to verify that the image you suggested was a ROM image and not a disk image. They are not the same and you'll never boot a TOS 1.0 ROM image like a disk.
MIDI Draw still fails to load with either US and UK TOS disk loaders anyway. It just freezes.
p.s. I can never do the quote thing!
Please accept my apologies @rubber_jonnie
No apologies necessaryCosmic Puppet wrote: Fri Jun 25, 2021 12:35 am I know you wasn't I'm just weird.
CTRL_ALT_REES recently produced a video regarding the original floppy TOS.
First time I'd ever seen it in action. Perhaps worth a goosey?
You need flashy clockCosmic Puppet wrote: Fri Jun 25, 2021 12:35 am MIDI Draw still fails to load with either US and UK TOS disk loaders anyway. It just freezes.
You just click on the "quote" button to reply to posts... and type at the bottom..
I picked up a 260ST a few years ago, "as is" (seller had no PSU or knowledge of the system), and was very pleased to find that it had the original floppy boot ROMs. I've actually never booted a floppy TOS on it though. But it was the first time I ever saw that rainbow coloured boot screen in person.Badwolf wrote: Fri Jun 25, 2021 10:15 am First time I'd ever seen it in action. Perhaps worth a goosey?
Mine is a German model with 512 KB on the board, and a piggyback expansion, which apparently was a fairly common original configuration for these systems.
- Cosmic Puppet
It's when I want to quote some of the text it goes wrong @exxosexxos wrote: You just click on the "quote" button to reply to posts... and type at the bottom..
- Cosmic Puppet
Thanks @Badwolf Will check this out.
Loved that colourful Atari start screen!
