Very nice...I'd be interested in a version of this if/when you're in a position to consider making or selling these.
:goodpost: :bravo: :thumbup:
DFB1r3 dev board demonstration video
Re: DFB1r3 dev board demonstration video
By the way, I mentioned in the video that I was experimenting with adding an FPU to the board. It doesn't work for me, alas.
It's recognised and under TOS the FRAC.DSP program will draw its Mandelbrot, but GB6 will crash. Under EmuTOS it's an exception on both.
I've a suspicion I've pushed my particular brand of firmware about as far as I can. I'm getting some odd fitting errors and any little tweak seems to break timing now despite vast swathes of macrocells being available. More work is needed there & therefore timing may be the problem.
In terms of wiring, I've:
- All 32 data lines connected
- DSACK[1:0] are connected direct and converted to open drain with 2k2 pullups
- A[4:1] connected to the address bus
- Clock, reset, RW, AS and DS bridged
- Chip Select being the only derived signal based on
&FC & ( A[19:16] == 4'b0010 ); // co-processor decode
TF536 hasBadwolf wrote: 21 May 2021 17:33
wire FPUOP = CPUSPACE & ({A[19:16]} === {4'b0010});-
Reylan
Hello,
I was wondering if it would be possible to stack the dfb1 on top is a ct60e.
To give a fully compatible and fast 68030 and a 68060.
Just to know 😊
Just to know 😊
Haha, I doubt it!Reylan wrote: 23 May 2021 08:14 Hello,
Just to know 😊
Cheers.exxos wrote: 22 May 2021 10:22 TF536 hasSo looks right to me :)Code: Select all
Been away for a week so will likely come back to this later this week. Suspecting possibly dodgy fly-leads, TBH.
MegaSTEarian
Any update on this wonderful project?
Yeah, sorry, not a lot for a number of reasons.
Basically I want a new, more efficient, more reliable firmware before I move back the FPU and rev4.
Cheers for chasing me up, though. :)
- I've been a way for a bit.
- I've been experimenting with other things.
- Cricket season has started so my weekends aren't as available.
- The FPU hat didn't work 'out of the box' and I hit a dead-end firmware-wise trying to make it so.
MegaSTEarian
Cheers, thanks for the update.
