People not getting web store emails
Re: People not getting web store emails
exxos wrote: 06 May 2021 16:39
You mean this.. ?
Yeah. That's not working.
Badwolf wrote: 06 May 2021 17:16 Yeah. That's not working.
Maybe it will magically start working in a few hours time :shrug:
oh...
sudo opendkim-testkey -d exxoshost.co.uk -s default -vvv
opendkim-testkey: using default configfile /etc/opendkim.conf
opendkim-testkey: checking key 'default._domainkey.exxoshost.co.uk'
opendkim-testkey: key not secure
opendkim-testkey: key OK
If you see Key not secure in the command output, don’t panic. This is because DNSSEC isn’t enabled on your domain name. DNSSEC is a security standard for secure DNS query. Most domain names haven’t enabled DNSSEC.
host -t any default._domainkey.exxoshost.co.uk
default._domainkey.exxoshost.co.uk descriptive text "v=DKIM1\; k=rsa\; p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAklxL/jc94pBcmiBhJjsJG5SEPa0MQUAClcl/pb6/5G1DqSqCb4VB0RdkZIBAkmvEkw1QU........
xyzzy76
Post by xyzzy76 »
I noticed you're using the bare domain for your mail server (exxoshost.co.uk)
Try using mail.exxoshost.co.uk as your mail server name, and set the PTR record to this as well.
220 exxoshost.co.uk ESMTP Postfix (Ubuntu) [235 ms]
EHLO keeper-us-east-1c.mxtoolbox.com
250-exxoshost.co.uk
A1200 rev 1B & 1230-IV 50MHz / CPC 6128 / CPC 464 / ZX Spectrum 48K / ZX81
exxos wrote: 06 May 2021 17:42 oh...
Certainly seeing something there now. Cool. Those mail testers will tell you if it's the *right* thing, though . ;-)
derkom
Post by derkom »
xyzzy76 wrote: 06 May 2021 18:37 I noticed you're using the bare domain for your mail server (exxoshost.co.uk)
I think this is sound advice, and also I think a big clue to the real cause of the problem lies in the example they gave of "generic" hostnames:
I bet what's happening here is they have some kind of pattern matching going on that thinks "exxoshost.co.uk" is generic hosting provider reverse DNS, because of the string "host" existing in the domain name. Depending on how they have their regular expression setup, tacking a hostname on the front as @xyzzy76 suggests may well stop it from tripping their "generic" pattern match.
They are all already setup though..
xyzzy76
Post by xyzzy76 »
Something like:
postconf -e 'myhostname = mail.exxoshost.co.uk'
xyzzy76 wrote: 06 May 2021 19:20 Something like:
ok ill change it.
derkom wrote: 06 May 2021 18:59 I bet what's happening here is they have some kind of pattern matching going on that thinks "exxoshost.co.uk" is generic hosting provider reverse DNS, because of the string "host" existing in the domain name. Depending on how they have their regular expression setup, tacking a hostname on the front as @xyzzy76 suggests may well stop it from tripping their "generic" pattern match.
To be fair, that alert was triggered by 12.101.4.84.rev.sfr.net rather than exxoshost.co.uk, which it became later.
Changing it means also changing the other infrastructure to match (MX record, for example) as most mailers will now check forward, reverse and MX match.
Users browsing this forum: Bing [Bot], ClaudeBot, petal [bot] and 0 guests
