Atari 1040 4MB RAM upgrade problems
kmcrainey
Post by kmcrainey »
Hello,
I have attempted this 4MB RAM upgrade, but when I turn the unit on, I am not getting a boot up sequence. The system produces a black screen through the video port. The gotek is getting power and the power light is lit. Listening to the device, I don't hear the normal "bzz" noises that periodically play, when the system is booting up. I assume the RAM is not working, now that I used this upgrade. Can anyone please help me diagnose the problem? I have attached some pictures. Any suggestions on what to try would be greatly appreciated.
Regards,
Malcolm
Re: Atari 1040 4MB RAM upgrade problems
Have a look though these threads..
https://www.exxosforum.co.uk/forum/viewforum.php?f=15
https://www.exxosforum.co.uk/forum/viewt ... =15&t=3959
https://www.exxosforum.co.uk/forum/viewt ... =15&t=3216
https://www.exxosforum.co.uk/forum/viewt ... =15&t=3217
You likely have a bad connection somewhere or a bad solder joint it's always the case.
It also looks like the RAM board is not correctly inserted into the socket fully...
DoG
Post by DoG »
It doesn't look like the mmu adapter and the shifter is fully inserted. Could be the angle of the photo maybe.
When you have a border with black screen it generally speaking means no memory.
The MMU adapter looks correctly aligned with pin 1 in the correct location, however it is not inserted nearly far enough. You should have only about 1mm of the pins visible when properly inserted.
I'd suggest that you completely remove the mainboard and place it on a piece of cardboard on a flat level surface before trying to push in the MMU adapter to ensure that you can use enough force, applied evenly, to ensure the adapter pushes in far enough.
Leaving it in the case allows the board to flex, which can also cause hidden damage, and prevents even insertion. I've had boards break just by pushing something into a socket.
As for the Shifter adapter, I don't think that is fully in either as it looks a bit high to me. It should be easier to insert than the MMU adapter but I still advise doing it with the board outside the case on a flat surface supported by cardboard.
Double check the Shifter orientation to make sure that pin 1 of the adapter and chip are in the right place.
After inserting the adapters, I'd suggest you check on the bottom of the board for any pins that may have bent over and are shorting. Atari often left component leads long enough for this to happen.
kmcrainey
Post by kmcrainey »
I tried my best to press down more like you recommended. I think I made some leeway, but the same result is occurring. I don't see any obvious damage on the bottom of the board. I did put some solder in one pin whole that didn't seem to have solder in it.
Maybe this is a dumb question but I don't have to mount the PSU with any screws or plug in the keyboard for the boot sequence to start normally, do I?
Please see attached photos.
kmcrainey wrote: Wed May 05, 2021 8:24 pm I tried my best to press down more like you recommended. I think I made some leeway, but the same result is occurring. I don't see any obvious damage on the bottom of the board. I did put some solder in one pin whole that didn't seem to have solder in it.
No, It'll boot just fine with the PSU sitting in place on the mobo, no screws, and the keyboard isn't necessary for boot.
What hole (Via) are you referring to that had no solder? Really you shouldn't solder anything unless you know what it does, and the ST does have a lot of unsoldered vias.
BTW, the 4th pin up on the left of your shifter looks bent and the shifter adapter doesn't look evenly plugged in, it's higher on the right hand side in your pictures.
friijy2001
Post by friijy2001 »
Hi,
I had a similar issue and it was just down to checking to make sure things were seated correctly.
As another test make sure all tracks and cables go somewhere, the cable should connect to a pin on the shifter, this can be done with a simple circuit tester if you have one.
The other thing I have found if you have removed things from the main board is it is really easy to break a track...on the underside of the board where the shifter sits make sure each track has a connection. (not all go to places but they should at least go to another place on the board.
Call me Stephen :)
friijy2001 wrote: Thu May 06, 2021 6:51 am The other thing I have found if you have removed things from the main board is it is really easy to break a track...on the underside of the board where the shifter sits make sure each track has a connection. (not all go to places but they should at least go to another place on the board.
I'll certainly second that about breaking tracks. I plugged an IDE adapter into my Mega 4s Megabus adapter and it broke 2 data data lines coming out of the CPU. Easily fixed, but bloody annoying!!
kmcrainey
Post by kmcrainey »
I did try and and perform continuity tests the shifter board and shifter IC. There were no issues. I also did a continuity test with the ribbon cable plugged into the shifter board and the there was no issue.
As for the hole I soldered, I don't remember which one it was. I will refrain from doing such an action again. What are the chances that this one time will cause an issue? Should I take a guess on it and remove the solder?
As for the underside of the board, I do have some scratches. Would this cause a problem? What can I do to correct this?
Regard,
Malcolm
@kmcrainey, please can you place your photos in-line when posting it makes the flow better and you can place them around your explanations. Examples here - https://www.exxosforum.co.uk/forum/viewt ... =20&t=2357
I have fixed them in this post already.
Return to “RAM UPGRADES”
