Re: REV 3 - The beginning
exxos wrote: Fri Apr 30, 2021 3:30 pm ah... :lol:
Go find some more ram and then try running from auto again...
You've 64 and a half megabytes!!
Badwolf wrote: Fri Apr 30, 2021 3:33 pm You've 64 and a half megabytes!!
Tell EMUTOS that :lol:
So EMUTOS booting from AUTO shows "EmuTOS Version 20210428" and Is just flashing very slowly and that is all that happens :roll:
This has console debug turned on and a few modules debug-enabled.
I've also changed the initinfo timeout to 10 seconds.
How far do you get? Can you read anything or does it vanish? If the latter, do you have a serial cable you can use?
emutos.zip
(246.59 KiB) Downloaded 133 times
Going back to running from ROM.. I managed to get EMUCON up.. but I have absolutely no idea what it is for ...
Badwolf wrote: Fri Apr 30, 2021 3:40 pm This has console debug turned on and a few modules debug-enabled.
exxos wrote: Fri Apr 30, 2021 3:52 pm
Interesting that you got to to EmuCON on the ROM version, but not even to the initial screen on the prog version (no AltRAM on the prog version either, BTW, so it shouldn't be that).
Anyone faster on the pause key than me see where that got to?
And sorry to labour the point as your previous answer wasn't entirely clear: this is mounted *instead of* the PLCC 68000 rather than in addition to it, yes?
Badwolf wrote: Fri Apr 30, 2021 4:26 pm Interesting that you got to to EmuCON on the ROM version, but not even to the initial screen on the prog version (no AltRAM on the prog version either, BTW, so it shouldn't be that).
The PRG Version does flash the splash screen occasionally, that is exactly what happens with the ROM version..
I did disable the alt-ram early on in testing yesterday to rule it out already anyway.
Badwolf wrote: Fri Apr 30, 2021 4:26 pm Anyone faster on the pause key than me see where that got to?
Badwolf wrote: Fri Apr 30, 2021 4:26 pm And sorry to labour the point as your previous answer wasn't entirely clear: this is mounted *instead of* the PLCC 68000 rather than in addition to it, yes?
I don't think you could run both CPUs like that... It would otherwise be pretty dumb if I just inserted the TF536 "on top" of the 68000.
Argh, so it's not consistent? Sometimes makes it to the welcome screen sometimes not?
EmuTOS probably won't help us here, then. I was hoping we could track down the code that was failing.
I know Stephen did some piggy-back tests over the 68k in his A600 so I wasn't sure if that were supported.
But if it's instead of rather than as well as, so much the simpler.
TBH it sounds like a dodgy connection to me. Perhaps messing up the address bus?
Is the motherboard RST line toggling when this happens?
Badwolf wrote: Fri Apr 30, 2021 4:59 pm Is the motherboard RST line toggling when this happens?
Yep.
Badwolf wrote: Fri Apr 30, 2021 4:59 pm TBH it sounds like a dodgy connection to me. Perhaps messing up the address bus?
Afew random data bus lines look noisy, so I will finish off tonight and see if I can find some small value caps to solder to snub some noise on them.
I think I'll just conclude that the bus is noisy like I always do. I'll just give it up as a bad job. I'm not really wanting to start diagnosing these old boards again. All this chaos is why I wanted to design a new motherboard in the first place.
Tried some 33pF's but no dice.
:comp:
It does get to desktop at 8MHz. So must be something tripping up somewhere at the higher speed :shrug: I have had a 68000 running at 40MHz on the STE before now, but not 50Mhz.
