Only a handful of very very crazy people will get one of them... :)freemilk wrote: 17 Apr 2021 16:55 By the way that KITT edition of the TF is FRICKN AWESOME< I would so go for an upgrade if you ever make more.
TF1260 stuff
- Admin sponsor
Re: TF1260 stuff
freemilk
Re: TF1260 stuff
I am CRAZY KRAZY. hit me up
hahhahahh
hahhahahh
freemilk
Re: TF1260 stuff
Well this BETA drive is not bad.
I just did disksalv and reorg on 3 of 4 CF cards, and they so far all turned out no problem. some had some checksum errors, so i though this is a good test, lol nothing important on them anyway.
#3 almost done and i will do #4,. i also have a 32 gig one that i will put on it and start my new image on.
Great work. cant wait for driver update.
Keith
Keith
Seb132
Re: TF1260 stuff
Sounds good to me.. I recently lost my funnel hat but I'm getting a new one from AliExpress... :excited:terriblefire wrote: 17 Apr 2021 16:58Only a handful of very very crazy people will get one of them... :)freemilk wrote: 17 Apr 2021 16:55 By the way that KITT edition of the TF is FRICKN AWESOME< I would so go for an upgrade if you ever make more.
GadgetUK164
Re: TF1260 stuff
:D Almost there!
GadgetUK164
Re: TF1260 stuff
Does anyone know what libs are required to get the LC version of the 060 working with SysInfo and AIBB?
I've tried MuLibs and MMULibs, as well as the LC version of 68060.library from SpeedGeek, but seemingly both benchmarks bomb when running a speed test. With MuLibs it thinks there's an FPU when there isn't.
EDIT: I am guessing I need a "none FPU version" of mathieeesingbas.library
But, people out there seem to suggest I would need to build a custom kick start ROM, can't I just find a fixed version of this and stick it in \Libs?
supaduper
Re: TF1260 stuff
I have sysinfo_4_nofpu but never tried it, link below
https://mega.nz/file/V1xmBRhR#fWx_YJY4g ... cBTpNgd0Rk
alenppc
- Moderator Team
Re: TF1260 stuff
Please stay as far away from that abomination as possible.
Sysinfo 4 will work on LC. But my recommendation is to use SysSpeed instead.
- Admin sponsor
Re: TF1260 stuff
I keep saying this....
THE ONLY 68060.LIBRARY that you ever need is in MMULib. DO NOT USE ANYTHING ELSE with at TF.
Do not convince yourself reading things on EAB. It's wrong. Thor and I worked to get MMUlib perfect for TF. Nothing else is needed.
GadgetUK164
Re: TF1260 stuff
Thanks, that's what I ended up using =D I just wasnt sure why SysInfo and AIBB where resetting the machine, but I've put the patched versions on you sent me and it's sorted =D Just about to test speed control, see if I can go a bit faster with this CPU =Dterriblefire wrote: 02 May 2021 16:43 I keep saying this....
Do not convince yourself reading things on EAB. Its wrong. Thor and I worked to get MMUlib perfect for TF. Nothing else is needed.
Lovely board, amazing work - incredible really, never thought I would see a new 060 CPU card for the 1200! I was surprised to see these have 128MB too! I thought it was going to be 64MB!
