TFMSX Arrives
Re: TFMSX Arrives
Wow! nice work, I don't know much about the MSX except there are a few different generations/versions - where does your home-made one fit compared to the others spec wise?
- Admin sponsor
Re: TFMSX Arrives
First issue with the TFMSX. I was trying to clock the Z80 with a 3.3v clock. It appears to need a VCC-0.6v minimum for high on the clock lines. Everything else is much less picky so i found a 74LVC1G17 chip and patched it on there.
Seems much happier now as i see RD wiggle furiously.
Re: TFMSX Arrives
exxos approves the bodge wires :lol: :thumbup:
Cheshire Noir
Re: TFMSX Arrives
Indeed, and a worthy pet project too. I'm just enjoying watching it get built. Somewhere down the track, if/when you release them to the usual suspects (And I have no expectations that this will happen, and want no part in applying any pressure for this to be anything more than a fun pet project for you) I'll probably see if I can purchase one. Not this year, however, as I am buying peripherals for all the systems I already own. So... many... shiny... systems!
Chesh
- Admin sponsor
Re: TFMSX Arrives
It’s alive!!!
Ok so this wasnt so straightforward. Adding the Schmitt buffer made the clock line ring like a church bell. and it didnt run at 3.58Mhz.
So now i need to make another one for @arkadiusz.makarenko so he can do the keyboard.
b_squared
Re: TFMSX Arrives
Great work, I'm excited to see what will come of this! MSX user since 1990 here. Two questions:
- Which BIOS are you using here?
- How are you handling cycles to the VDP for the turbo modes? Did you hook up the /WAIT signal?
- Admin sponsor
Re: TFMSX Arrives
I'm presently using the Bios from a HX-10.. keeping at simple as possible.
I've no turbo modes setup yet. but when i do i'll change CPU speed for different accesses so that VDP will always be at 3.58Mhz..
If anyone is interested the board uses 600mA @5V idling at a basic prompt.
arkadiusz.makarenko
- Moderator Team
Re: TFMSX Arrives
:O
That was quick.
That was quick.
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Re: TFMSX Arrives
Yeah i need some help now! :D USB keyboard!!!!
Here is how the keyboard matrix map looks...
PC0-3 are connected to the ARM like...
PC0 = ARM PIN8
PC1 = ARM PIN9
PC2 = ARM PIN10
PC3 = ARM PIN11
PB0 = ARM PIN 14
PB1 = ARM PIN 15
PB2 = ARM PIN 16
PB3 = ARM PIN 17
PB4 = ARM PIN 20
PB5 = ARM PIN 21
PB6 = ARM PIN 22
PB7 = ARM PIN 23
arkadiusz.makarenko
- Moderator Team
Re: TFMSX Arrives
I can find time for this... :)
~ Stanislaw Lem
~ Stanislaw Lem
