I've had a couple of the DSP508 which are only outputting half voltage (under load) ..
- IMG_6270.JPG (385.24 KiB) Viewed 2112 times
It was found in both cases a bad joint on the heatsink, which is being used as part of the mains circuit it seems
- IMG_6272.JPG (253.81 KiB) Viewed 2112 times
- IMG_6273.JPG (228.71 KiB) Viewed 2112 times
Re-soldered..
- IMG_6274.JPG (316.75 KiB) Viewed 2112 times
- IMG_6275.JPG (347.79 KiB) Viewed 2112 times
Done! The voltage is showing higher than it should as they battery is going in my meter, but it's actually 5.02V!
