DSP508 half voltage output fix
Repairs & upgrades.
I've had a couple of the DSP508 which are only outputting half voltage (under load) ..
It was found in both cases a bad joint on the heatsink, which is being used as part of the mains circuit it seems :roll:
Re-soldered..
Done! The voltage is showing higher than it should as they battery is going in my meter, but it's actually 5.02V!
Re: DSP508 half voltage output fix
The very similar ASP34 suffers from bad joints on the heatsink as well...
kodak80
Post by kodak80 »
Thank you @exxos I had a PSU here that was outputting half-voltages under load. This made me check the heatsink pin soldering and I found a crack so re-soldered all heatsink pins and viola the PSU is working again and outputs normal voltages again. :cheer:
PSU solder crack - half voltage under load is the result (kodak80).jpg (268.56 KiB) Viewed 2087 times
