JP18 and JP19 linked (720 mode)
JP22: 2&3 (8MHz 1772)
Are those the ones you are referring to?
Oh, interesting (that the GAL with SJ3 soldered did not work).kodak80 wrote: Fri Mar 05, 2021 9:06 pm I need to get back to testing the 1.44mb GAL but my initial testing with the SJ3 soldered did not work and only 720k disk images on my Gotek worked. Are your disk images 720k or 1.44mb?
720k disk images work fine for me regardless of what the GAL was set to do. Just could not get 1.44mb disks to read from my Gotek. I need to check that 16mhz feed from the shifter looks correct with my scope and do some further testing.AndresPlazaR wrote: Fri Mar 05, 2021 10:09 pm Oh, interesting (that the GAL with SJ3 soldered did not work).
I'm using 720k images.
Pin 1 in the GAL measures 16MHz +/- 0.12 : Pin 18 in the 1772 (@kodak80 ) measures 8MHz +/- 0.13 :exxos wrote: Fri Mar 05, 2021 4:39 pm You may have to scope the 16Mhz line to see how it looks on pin 1 of the GAL...
What clock do you get on GAL pin 14 which is clock output from GAL to WD1772?
These look normal clocks.AndresPlazaR wrote: Fri Mar 05, 2021 10:30 pm
There is no clock on GAL pin 14, only 5v.kodak80 wrote: Fri Mar 05, 2021 10:38 pm What clock do you get on GAL pin 14 which is clock output from GAL to WD1772?
With JP18 and JP19 shorted, I believe GAL should generate standard 8mhz clock on pin 14.
Did you program the GAL yourself ? Either its not programmed correctly, or faulty GAL by the sounds of it.
Good spot!kodak80 wrote: Fri Mar 05, 2021 10:46 pm JP19 on the H5 schematic may not be correct if as the label on this should be HD1_SEL but it showing in the released H5A schematics as N$57. This may mean that the GAL pin 4 is not connected to JP19 and impact GAL functionality?
