STE mods
Re: STE mods
Post by HigashiJun »
I have just reverted to my original configuration and everything works again... :D
So the memory is not the culprit and works just fine without parity chips.
I am pretty sure the booster would work with the bent pins method IngoQ did, but I think there is something wrong with the alternative method (cut trace and 2 solder spots) IngoQ further discovered.
If one of you guys have some clues or ideas, please share.
But meanwhile, let's wait for Exxos new plug-in booster ;)
Cheers.
Re: STE mods
Some feedback here on my last attempts to make the booster work (before testing Exxos' new beta booster).
After checking connections, I noticed a wire was de-soldered. My previous issues were surely related to this, as once the wire securely soldered again, my STE starts with no problems. :oops:
But:
- my Ultrasatan powers-on without booting from SD card (even in 8 Mhz mode)
- the FDD does not work with booster at 32Mhz (=Your Output Device is not receiving Data)
- the FDD works flawlessly with booster switched back to 8 Mhz
Could these problems be related to the resistor on the booster ? I swapped the original one for a 68R as suggested by Exxos.
Any comments are welcome.
Cheers.
Re: STE mods
Soldered back the original resistor (470R) on the booster but my STE does not boot...
Re: STE mods
You not got one of these by any chance ?
https://www.exxosforum.co.uk/forum/viewt ... 685#p57665
Also what resistor are you referring to ?
Do you man these mods ? https://www.exxosforum.co.uk/forum/viewt ... =20#p41514
Also note the capacitor ...
Re: STE mods
Ok, all the wires connecting to the booster are completely removed.
The cut trace is now functional again and everything is (almost) ready to test the new beta plug-in booster.
I guess the value of the resistor is somehow related to the FDD and Ultrasatan issues.
IngoQ seems to have the same mainboard revision as mine and he did not experienced any problems...
I think previous booster batches had a different resistor than 470R.
Re: STE mods
exxos wrote: 13 Feb 2021 09:10 You not got one of these by any chance ?
No, I have the Lotharek version:
Yes, I meant that mods.
The capacitor was also removed when I swapped the resistor.
Re: STE mods
HigashiJun wrote: 13 Feb 2021 09:27 The capacitor was also removed when I swapped the resistor.
Have you tried with no resistor or capacitor ?
Re: STE mods
exxos wrote: 13 Feb 2021 09:28
No, I did not.
Too late now as everything went back to its quite original state...
But anyway I am happy the booster worked somehow.
And it would surely have worked without any glitch if I could spend more time on it, but I prefer concentrate on your beta version which is more aesthetical...
Users browsing this forum: ClaudeBot, facebookexternalhit and 6 guests
