Address error on ST diagnostic cart ?
General Discussion, STOS.
Anyone know what the ST diagnostic cart is doing at that address ? Its repeatable every time, same numbers :shrug:
Re: Address error on ST diagnostic cart ?
exxos wrote: Sun Jan 31, 2021 10:21 pm Anyone know what the ST diagnostic cart is doing at that address ? Its repeatable every time, same numbers :shrug:
Is this missing a picture @exxos ?
rubber_jonnie wrote: Sun Jan 31, 2021 11:40 pm Is this missing a picture @exxos ?
ah crap, must have forgot.. should make more sense now :lol: :roll:
I've seen this sort of thing when the diag cart is set to the wrong machine type, might be worth a check.
rubber_jonnie wrote: Sun Jan 31, 2021 11:49 pm I've seen this sort of thing when the diag cart is set to the wrong machine type, might be worth a check.
Its a TF536 on a H4 , so not sure what the machine type actually is :lol: in TOS206 it hangs just after the Fuji, I think its relating to the floppy drive as it doesn't seem to do its normal reset chug ... Its why I booted the diagnostic cart to see what it said... I might try digrom tomorrow see what that makes of it.. Oddly I can run YAART from cartridge..and all is fine... So its really working out why its getting stuck at the point it does currently...
frank.lukas
Post by frank.lukas »
You can not use the Atari cart diagnostic if the machine is not original (CPU, TOS etc.) ...
exxos wrote: Mon Feb 01, 2021 12:25 am
I think given what Frank said, Diagrom is going to be a better option.
Return to “SOFTWARE”
