Anyone know what the ST diagnostic cart is doing at that address ? Its repeatable every time, same numbers :shrug:
Address error on ST diagnostic cart ?
Re: Address error on ST diagnostic cart ?
Is this missing a picture @exxos ?exxos wrote: 31 Jan 2021 22:21 Anyone know what the ST diagnostic cart is doing at that address ? Its repeatable every time, same numbers :shrug:
ah crap, must have forgot.. should make more sense now :lol: :roll:
I've seen this sort of thing when the diag cart is set to the wrong machine type, might be worth a check.
Its a TF536 on a H4 , so not sure what the machine type actually is :lol: in TOS206 it hangs just after the Fuji, I think its relating to the floppy drive as it doesn't seem to do its normal reset chug ... Its why I booted the diagnostic cart to see what it said... I might try digrom tomorrow see what that makes of it.. Oddly I can run YAART from cartridge..and all is fine... So its really working out why its getting stuck at the point it does currently...rubber_jonnie wrote: 31 Jan 2021 23:49 I've seen this sort of thing when the diag cart is set to the wrong machine type, might be worth a check.
frank.lukas
You can not use the Atari cart diagnostic if the machine is not original (CPU, TOS etc.) ...
I think given what Frank said, Diagrom is going to be a better option.exxos wrote: 01 Feb 2021 00:25Its a TF536 on a H4 , so not sure what the machine type actually is :lol: in TOS206 it hangs just after the Fuji, I think its relating to the floppy drive as it doesn't seem to do its normal reset chug ... Its why I booted the diagnostic cart to see what it said... I might try digrom tomorrow see what that makes of it.. Oddly I can run YAART from cartridge..and all is fine... So its really working out why its getting stuck at the point it does currently...rubber_jonnie wrote: 31 Jan 2021 23:49 I've seen this sort of thing when the diag cart is set to the wrong machine type, might be worth a check.
