TF536 no RAM detected
68030 + SDRAM + IDE
Re: TF536 no RAM detected
Data bus bit D10 is shorted to power on the RAM.
This is the chip nearest the cpld.
ninjafahrer
Post by ninjafahrer »
ok, i will check this...
On the 2nd board everything gets retained, but Autoconfig dont see the board...
ninjafahrer wrote: 26 Jan 2021 16:12 ok, i will check this...
Autoconfig doesnt "see" anything. Autoconfig is just a little rom that the OS reads to understand that there is memory. The memory is always here. Do you get the colour bars?
Anyways lets do these boards one at a time or it will get confusing fast... see above i posted a picture of which pins to check.
alenppc
Moderator Team
Moderator Team
Post by alenppc »
May I also suggest checking all the connections with a microscope... these boards are farily simple and it should be easy to spot any shorts or missoldered pins, but you do need a microscope.
ninjafahrer
Board 1 MEMORY -> SOLVED!
Great! Thanks for your help...!!!
on Board 2 - please explain what do you mean with colour bars?
ninjafahrer wrote: 26 Jan 2021 16:28 on Board 2 - please explain what do you mean with colour bars?
When you boot kickstart. Do you see the colour bars. Your first board will do this if its working.
ninjafahrer
no, there is no colour bar shown at card 2.
card 1 is working now :D
ninjafahrer wrote: 26 Jan 2021 16:51 no, there is no colour bar shown at card 2.
Either AS or DS is not connected correctly..
Go to address 0x00f00000 in the memory editor and see what you get there..
ninjafahrer
61 1A D9 1A D9...
ninjafahrer wrote: 26 Jan 2021 17:29 61 1A D9 1A D9...
So if you have a look at the other board it will show
11 11 49 F9 00 DF F0 00 30 3C 7F FF 39 40 00 9A
since you are getting a repeating pattern i'm guessing the CPLD is for whatever reason not responding to any internal data requests.
Return to “TF536”
Users browsing this forum: ClaudeBot, Google [Bot] and 4 guests
