My first TF536
68030 + SDRAM + IDE
Lynxman
My first TF536
Post by Lynxman »
I soldered my cpu directly to the PCB and snipped off the pins underneath. It fits under the keyboard with clearance now in my zombie 500+. It's in the way of one of the RF shield tabs though.
Running at 40 MHz. Waiting for 100 MHz oscillators to get here to get to 50 MHz.
Mark Sealey
Re: My first TF536
Post by Mark Sealey »
looks tidy...nice one
A500+ Pistorm EMU68... A600 Furia 020/33....A1200 TF1230
Lynxman
Re: My first TF536
Post by Lynxman »
The TF536 has better compatibility with WHDLoad games than the TF534. All the games I couldn't get working before now work. Zeewolf 1 and 2, Joungle Strike 2MB version, F18 Interceptor would crash with TF534.
PaulJ_2.0
Re: My first TF536
Post by PaulJ_2.0 »
What's the deal with the two RTC?
Nice build BTW
supaduper
Re: My first TF536
Post by supaduper »
I`ll answer , some A500 ram expansions had RTCs because only the A500+ had an RTC the first A500 did not
Lynxman
Re: My first TF536
Post by Lynxman »
Yes. I originally built that red RAM expansion for my A500, and when I got this A500+ I moved it over the the A500+ because it has room for another ram chip to give 1 MB extra chip ram. I then put another old school expansion that only could have 512 kB in my old A500. I omitted the motherboard battery because of the clock on the ram board and it seems to work fine. It's more practical to have battery access from the expansion bay anyway.
Lynxman
Re: My first TF536
Post by Lynxman »
I cut the corner of the TF536 so that the RF shield will fit. There's a capacitor on the bottom that prevented me from cutting further in but it fits after bending the leg on the shield slightly. I could move the cap over to the leg of the chip but this will do. Stephen if you want to make it so that it doesn't nee a relocator that's all it takes. If the 68000 socket headers were moved down to the edge it would alsowork and the CPU could probably be fitted with a socket as it would sit farter in.
I also cut slots in the shield to give room for my expansion door CF holder. Almost looks factory.
You can download my 3D printable expansion doors here: https://www.exxosforum.co.uk/forum/viewt ... 297#p56297
8 Bit Dreams
Moderator Team
Moderator Team
Re: My first TF536
Post by 8 Bit Dreams »
Wow! Hopefully You was prepared to see fireworks on power on, since these are four-layer boards. Cutting them may short out GND and VCC inner layers.. :shock:
go0se
Re: My first TF536
Post by go0se »
8 Bit Dreams wrote: Thu Jan 21, 2021 8:20 pm Wow! Hopefully You was prepared to see fireworks on power on, since these are four-layer boards. Cutting them may short out GND and VCC inner layers.. :shock:
Where's your sense of adventure?? :lol:
Lynxman
Re: My first TF536
Post by Lynxman »
I checked off course. :)
Return to “TF536”
