DKB MegAChip
General hardware issues and troubleshooting etc
GianDO
DKB MegAChip
Post by GianDO »
Hi,
These days I found a DKB MegAChip, I connected it following what is written in the manual. But I have noticed that when I turn on my computer I sometimes get a green screen and then it continues booting. I also saw that on the upper line of the workbench where the memory is indicated that the ChipRAM is much less than 2 MByte. What could it depend on?
Thanks
G
A2000 - MC68000 - KS3.1 - WB 3.1 - 2MB ChipRAM - Impact A2000-HC+8 Series II - 8 MB FastRAM - SD2SCSI 16GB - Indivision ECS
matt020
Re: DKB MegAChip
Post by matt020 »
Have you got the additional wire connected to Gary?
Can you upload a picture of the chip and how it is installed into the motherboard?
GianDO
Re: DKB MegAChip
Post by GianDO »
matt020 wrote: 11 Nov 2020 22:01 Have you got the additional wire connected to Gary?
Yes, the cable is connected to pin 36 of the Gary. The green screen doesn't show it anymore. The system boots, but always shows little chipram.
dalek
Re: DKB MegAChip
Post by dalek »
Most likely contact issues. I'd remove the megachip and clean the socket pins and megachip contacts with contact cleaner.
GianDO
Re: DKB MegAChip
Post by GianDO »
dalek wrote: 11 Nov 2020 23:41 Most likely contact issues. I'd remove the megachip and clean the socket pins and megachip contacts with contact cleaner.
I tried to clean the contacts with the anti-oxidant spray for electronic components, but nothing has changed.
Re: DKB MegAChip
GianDO wrote: 12 Nov 2020 12:57
What happened to the micronik. Please finish these threads off! tell us what happened.
GianDO
Re: DKB MegAChip
Post by GianDO »
terriblefire wrote: 12 Nov 2020 14:12 What happened to the micronik. Please finish these threads off! tell us what happened.
Excuse me. I forgot to write the conclusion and I have concluded that thread now.
Thank you
G
Re: DKB MegAChip
Its worth testing that Angus is working and its a version compatible with that board.
https://en.wikipedia.org/wiki/MOS_Technology_Agnus
The different chips have different pinouts.
GianDO
Re: DKB MegAChip
Post by GianDO »
terriblefire wrote: 12 Nov 2020 16:23 Its worth testing that Angus is working and its a version compatible with that board.
The DBK Agnus is identical to the Micronik Agnus.
I put the DBK Agnus in place of the Micronik Agnus and the Micronik still works fine.
Then I put the Micronik Agnus in the DBK and the DBK gives the usual problem.
At this point it is not a problem of the Agnus.
Re: DKB MegAChip
GianDO wrote: 12 Nov 2020 18:40
Thats not necessarily true. The Micornik and the DKB could need different Agnus pinouts.
EDIT: Doesnt look likely though you seem to have the same chip as they come with normally
Return to “AMIGA HARDWARE HELP”
Users browsing this forum: Bing [Bot], ClaudeBot and 12 guests
