DKB MegAChip
DKB MegAChip
Hi,
These days I found a DKB MegAChip, I connected it following what is written in the manual. But I have noticed that when I turn on my computer I sometimes get a green screen and then it continues booting. I also saw that on the upper line of the workbench where the memory is indicated that the ChipRAM is much less than 2 MByte. What could it depend on?
Thanks
G
Thanks
G
A2000 - MC68000 - KS3.1 - WB 3.1 - 2MB ChipRAM - Impact A2000-HC+8 Series II - 8 MB FastRAM - SD2SCSI 16GB - Indivision ECS
Re: DKB MegAChip
Have you got the additional wire connected to Gary?
Can you upload a picture of the chip and how it is installed into the motherboard?
Re: DKB MegAChip
matt020 wrote: Wed Nov 11, 2020 10:01 pm Have you got the additional wire connected to Gary?
Yes, the cable is connected to pin 36 of the Gary. The green screen doesn't show it anymore. The system boots, but always shows little chipram.
Re: DKB MegAChip
Most likely contact issues. I'd remove the megachip and clean the socket pins and megachip contacts with contact cleaner.
Re: DKB MegAChip
dalek wrote: Wed Nov 11, 2020 11:41 pm Most likely contact issues. I'd remove the megachip and clean the socket pins and megachip contacts with contact cleaner.
I tried to clean the contacts with the anti-oxidant spray for electronic components, but nothing has changed.
- Admin sponsor
Re: DKB MegAChip
What happened to the micronik. Please finish these threads off! tell us what happened.GianDO wrote: Thu Nov 12, 2020 12:57 pmdalek wrote: Wed Nov 11, 2020 11:41 pm Most likely contact issues. I'd remove the megachip and clean the socket pins and megachip contacts with contact cleaner.
Re: DKB MegAChip
terriblefire wrote: Thu Nov 12, 2020 2:12 pm What happened to the micronik. Please finish these threads off! tell us what happened.
Excuse me. I forgot to write the conclusion and I have concluded that thread now.
Thank you
G
- Admin sponsor
Re: DKB MegAChip
Its worth testing that Angus is working and its a version compatible with that board.
https://en.wikipedia.org/wiki/MOS_Technology_Agnus
The different chips have different pinouts.
Re: DKB MegAChip
The DBK Agnus is identical to the Micronik Agnus.terriblefire wrote: Thu Nov 12, 2020 4:23 pm Its worth testing that Angus is working and its a version compatible with that board.
I put the DBK Agnus in place of the Micronik Agnus and the Micronik still works fine.
Then I put the Micronik Agnus in the DBK and the DBK gives the usual problem.
At this point it is not a problem of the Agnus.
- Admin sponsor
Re: DKB MegAChip
Thats not necessarily true. The Micornik and the DKB could need different Agnus pinouts.GianDO wrote: Thu Nov 12, 2020 6:40 pmThe DBK Agnus is identical to the Micronik Agnus.terriblefire wrote: Thu Nov 12, 2020 4:23 pm Its worth testing that Angus is working and its a version compatible with that board.
EDIT: Doesnt look likely though you seem to have the same chip as they come with normally
