exxos blog - random goings on
Yeah, just one would be enough. I might have to hone up my SMD soldering skills about 5 levels to put the CPU on there though! :-)
stephen_usher wrote: 28 Oct 2020 16:56 Yeah, just one would be enough. I might have to hone up my SMD soldering skills about 5 levels to put the CPU on there though! :-)
If you get one with bent pins then it'll take you forever to get everything lined up and soldered. Even with all the pins straight they are a pain to solder.
Noted. I'd have to use hot air on that scale of device.
I don't s'pose you know of a good source for them?
stephen_usher wrote: 28 Oct 2020 17:55 Noted. I'd have to use hot air on that scale of device.
I believe exxos ordered them from Aliexpress.
Thanks... so pot luck then.
stephen_usher wrote: 28 Oct 2020 18:26 Thanks... so pot luck then.
I've built four and all four will run at 50mhz for at least two hours each but with a heatsink.
Is this the correct type? "MC68030FE33C MC68030 QFP-132"
stephen_usher wrote: 28 Oct 2020 18:45 Is this the correct type? "MC68030FE33C MC68030 QFP-132"
Sorry only just seen this post.. I got them from here.. https://www.aliexpress.com/item/4001034 ... 4c4dOptuSX but @PhilC said the pins were bent.
Got these in the UScleaner :)
DoG
Post by DoG »
exxos wrote: 03 Nov 2020 14:27 Got these in the UScleaner :)
:dualthumbup:
Users browsing this forum: ClaudeBot, Google [Bot], rubber_jonnie, Steve and 19 guests
