exxos blog - random goings on
Yeah, just one would be enough. I might have to hone up my SMD soldering skills about 5 levels to put the CPU on there though! :-)
If you get one with bent pins then it'll take you forever to get everything lined up and soldered. Even with all the pins straight they are a pain to solder.stephen_usher wrote: 28 Oct 2020 16:56 Yeah, just one would be enough. I might have to hone up my SMD soldering skills about 5 levels to put the CPU on there though! :-)
Noted. I'd have to use hot air on that scale of device.
I don't s'pose you know of a good source for them?
I believe exxos ordered them from Aliexpress.stephen_usher wrote: 28 Oct 2020 17:55 Noted. I'd have to use hot air on that scale of device.
Thanks... so pot luck then.
I've built four and all four will run at 50mhz for at least two hours each but with a heatsink.
Is this the correct type? "MC68030FE33C MC68030 QFP-132"
Sorry only just seen this post.. I got them from here.. https://www.aliexpress.com/item/4001034 ... 4c4dOptuSX but @PhilC said the pins were bent.
Got these in the UScleaner :)
DoG
:dualthumbup:
Users browsing this forum: ClaudeBot, Icky and 38 guests
