Scandoubler /Flicker fixer
General hardware issues and troubleshooting etc
GadgetUK164
Re: Scandoubler /Flicker fixer
Post by GadgetUK164 »
terriblefire wrote: Fri Oct 16, 2020 8:19 am
GadgetUK164 wrote: Fri Oct 16, 2020 12:07 am It's open source by the looks of it. I was going to try and order it but unfamilar with how the gerber files are structured and named there. DirtyPCBs seems to like everything having a .gbr extension with a seperate extention for the drill files and the cuts file. At the bottom of that page is the link to the bom and gerbers (in one zip on aminet).
Just ordered 5 PCs. Will send you one when they arrive.
Design of the board looks good. I think i might be able to improve on the CPLD firmware.
EDIT: Only thing i would change about the board is to make it 4 layer.
Wow, that's awesome!!!
GianDO wrote: Fri Oct 16, 2020 10:10 am It will also be well made, but if you see half the screen ...
Then i will fix the firmware.
GianDO
Post by GianDO »
terriblefire wrote: Fri Oct 16, 2020 10:59 am
so the fact that it doesn't show full screen is just a matter of firmware?
A2000 - MC68000 - KS3.1 - WB 3.1 - 2MB ChipRAM - Impact A2000-HC+8 Series II - 8 MB FastRAM - SD2SCSI 16GB - Indivision ECS
GianDO wrote: Fri Oct 16, 2020 11:05 am so the fact that it doesn't show full screen is just a matter of firmware?
not 100% known but thats usually down to vga timings.
GianDO
Post by GianDO »
terriblefire wrote: Fri Oct 16, 2020 11:10 am
If it worked correctly it would be a great alternative to the other more expensive and hard to find scandoublers. Also because it seems to me that there are not many alternatives around ..
GianDO wrote: Fri Oct 16, 2020 12:13 pm
Personally I have not been interested in these kind of scandoublers because external ones are so good. Generally I want to use Amiga on standard TV.
GianDO
Post by GianDO »
terriblefire wrote: Fri Oct 16, 2020 12:20 pm
But can you get high resolutions even on standard TVs?
GianDO wrote: Fri Oct 16, 2020 12:27 pm But can you get high resolutions even on standard TVs?
Its never been something i wanted to do on Amiga
GianDO
Post by GianDO »
terriblefire wrote: Fri Oct 16, 2020 12:32 pm
Ok, instead on my amiga 2000 I have a Picasso II and I would like to use it, but at the same time I would like to display the standard amiga resolutions without having to use two monitors ..
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
You should get one of Mazes Flicker Fixer cards, then
Return to “AMIGA HARDWARE HELP”
