Scandoubler /Flicker fixer
GianDO
Post by GianDO »
Hello,
does anyone know the scandoubler / flicker fixer developed by Simon Albert?
https://www.lighttech-hg.de/index.php/o ... candoubler
I would like to know if it can be good for my A2000 or has any contraindications ..
Thank you
G
A2000 - MC68000 - KS3.1 - WB 3.1 - 2MB ChipRAM - Impact A2000-HC+8 Series II - 8 MB FastRAM - SD2SCSI 16GB - Indivision ECS
Aeberbach
Re: Scandoubler /Flicker fixer
Post by Aeberbach »
Only that it is limited in the amount of screen real estate it covers on the output monitor. But that's a result of it not being overly complicated, I would prefer that than the OSSC approach that plugs into anything and scales to just about anything - you don't have to deal with an analog video signal input, you don't have to learn to configure the thing through 18 menus and calculate your scan frequencies and dot clock like it's 1994 and you're configuring X-Windows :lol:
GianDO
Post by GianDO »
You just confirmed what I understood. It seems like a good reason not to buy it .. Are there other A2000 scandoublers that use the video slot?
GianDO wrote: Thu Oct 15, 2020 11:31 pm You just confirmed what I understood. It seems like a good reason not to buy it .. Are there other A2000 scandoublers that use the video slot?
Is it offered for sale somewhere?
GianDO
Post by GianDO »
yes it is offered for sale on ebay
GadgetUK164
Post by GadgetUK164 »
It's open source by the looks of it. I was going to try and order it but unfamilar with how the gerber files are structured and named there. DirtyPCBs seems to like everything having a .gbr extension with a seperate extention for the drill files and the cuts file. At the bottom of that page is the link to the bom and gerbers (in one zip on aminet).
matt020
Post by matt020 »
The Commodore Amber card for the A2000 is top notch! I have one and the screen output on a modern LCD monitor is perfect!
GadgetUK164 wrote: Fri Oct 16, 2020 12:07 am It's open source by the looks of it. I was going to try and order it but unfamilar with how the gerber files are structured and named there. DirtyPCBs seems to like everything having a .gbr extension with a seperate extention for the drill files and the cuts file. At the bottom of that page is the link to the bom and gerbers (in one zip on aminet).
Just ordered 5 PCs. Will send you one when they arrive.
Design of the board looks good. I think i might be able to improve on the CPLD firmware.
EDIT: Only thing i would change about the board is to make it 4 layer.
GianDO
Post by GianDO »
matt020 wrote: Fri Oct 16, 2020 1:07 am The Commodore Amber card for the A2000 is top notch! I have one and the screen output on a modern LCD monitor is perfect!
You're lucky, I would need one too, but I doubt it can still be found. What alternatives would I have?
GianDO
Post by GianDO »
terriblefire wrote: Fri Oct 16, 2020 8:19 am
It will also be well made, but if you see half the screen ...
