Hi,
I cannot seem to find a newer version of the TF536 online (via Github), just this one : tf536_2019_06_14_alpha.zip. Can someone point me in the right direction?
Thanks,
Latest TF536 Firmware?
Re: Latest TF536 Firmware?
AFAIK that is the only official release of firmware.
Drewlio77
Oh my goodness, 16 months old. Oh well, I had to ask :)
alenppc
- Moderator Team
Actually the latest Amiga firmware is dated 2020-08-02 and can be found in the A2000 TF536 thread.
This firmware won't work on the A600 however, you need the one dated 2020-04-05 for that.
@alenppc Could you dump these firmwares in the new firmware forum :)
alenppc
- Moderator Team
Drewlio77
bnice7
I can try to put something together for this over the weekend. I don't remember what packages I had to install, but I can provide the pinouts and the commands.Drewlio77 wrote: 01 Oct 2020 04:04 It appears the website that had the Pi flash instructions has been removed. Can anyone GUIDE me in the direction to obtain these instructions (pun intended).
Drewlio77
That would be great. Thanks.
supaduper
I did a HOWTO ages ago for the TF330 but you can easily use it for the TF536
Here is my guide with the info needed to flash with raspberry pi, in one post there is a link to my Raspian 8gb image which has all the programming software on it ready to use, you will just have to use your own firmware jeds
This was on a Rasp pi 3 but should be ok on a 2...BUT CHECK YOU HAVE THE RIGHT PINOUTS !
The `Howto and 8gb Rasperry Pie image are in two posts halfway down the thread
My raspbian is passworded its ` Backlash1`
https://www.exxosforum.co.uk/forum/viewt ... 8&start=10
