Latest TF536 Firmware?
68030 + SDRAM + IDE
Drewlio77
Post by Drewlio77 »
Hi,
I cannot seem to find a newer version of the TF536 online (via Github), just this one : tf536_2019_06_14_alpha.zip. Can someone point me in the right direction?
Thanks,
Re: Latest TF536 Firmware?
AFAIK that is the only official release of firmware.
Drewlio77
Post by Drewlio77 »
exxos wrote: Sun Sep 27, 2020 11:13 am AFAIK that is the only official release of firmware.
Oh my goodness, 16 months old. Oh well, I had to ask :)
alenppc
Post by alenppc »
Actually the latest Amiga firmware is dated 2020-08-02 and can be found in the A2000 TF536 thread.
This firmware won't work on the A600 however, you need the one dated 2020-04-05 for that.
@alenppc Could you dump these firmwares in the new firmware forum :)
alenppc
Post by alenppc »
exxos wrote: Sun Sep 27, 2020 6:38 pm @alenppc Could you dump these firmwares in the new firmware forum :)
Done!
Drewlio77
Post by Drewlio77 »
alenppc wrote: Sun Sep 27, 2020 6:54 pm
Done!
It appears the website that had the Pi flash instructions has been removed. Can anyone GUIDE me in the direction to obtain these instructions (pun intended).
bnice7
Post by bnice7 »
Drewlio77 wrote: Thu Oct 01, 2020 4:04 am It appears the website that had the Pi flash instructions has been removed. Can anyone GUIDE me in the direction to obtain these instructions (pun intended).
I can try to put something together for this over the weekend. I don't remember what packages I had to install, but I can provide the pinouts and the commands.
Drewlio77
Post by Drewlio77 »
That would be great. Thanks.
supaduper
Post by supaduper »
I did a HOWTO ages ago for the TF330 but you can easily use it for the TF536
Here is my guide with the info needed to flash with raspberry pi, in one post there is a link to my Raspian 8gb image which has all the programming software on it ready to use, you will just have to use your own firmware jeds
This was on a Rasp pi 3 but should be ok on a 2...BUT CHECK YOU HAVE THE RIGHT PINOUTS !
The `Howto and 8gb Rasperry Pie image are in two posts halfway down the thread
My raspbian is passworded its ` Backlash1`
https://www.exxosforum.co.uk/forum/viewt ... 8&start=10
Return to “TF536”
