It comes with a 5V USB power connector which I provided with a plug.
Tried it today without the power switched on.
The LED lights up when my Atari is powered on so I assume it's getting its 5V from the Atari. It also switches to my second monitor no problem.
Powered on it changes my Atari Desktop colour!
Why is everything a rabbit hole.
Do I not need to plug this in then?
:roll:
Why are devices coming with 5V USB when it's not needed?
Also, how is the power changing the colour?
UGREEN VGA Switcher.
Cosmic Puppet
Cosmic Puppet
Re: UGREEN VGA Switcher.
Any idea what's going on here @Steve ?
That's odd.. looks like the 5v is leaking into the r/g/b lines somehow. It is a digital switch and looking at the reviews on amazon there are many people having issues with it... I personally just use a simple mechanical switchbox for my TT's two outputs which works fine, & a more expensive Belkin powered KVM for my other machines, so I can certainly recommend Belkin (They are expensive new, but can be found dirt cheap on ebay usually, from old offices)
I would return that switch as faulty to amazon personally...
Here is a nice little Belkin 2 porter, really cheap too & new: https://www.ebay.co.uk/itm/NEW-Belkin-F ... 4280320732
And if you have a spare 12v cable, here is a cheap & professional 4 porter with audio (note you will need gender changers too):
https://www.ebay.co.uk/itm/BELKIN-F1DS1 ... 4868452991
Cosmic Puppet
Thanks @Steve
I'll start looking through later. My Audio comes straight out of the VGA Adapter. I use the OSSC firmware without Audio as I just go into a Xenyx amp from there.
That first device confuses me with its USB ports. Does that do 1 computer to 2 monitors switchably? (There's no benefit of me seeing both at once)
I still have the box so could send that UGREEN one back. I don't mind spending more if it's good. Just Atari in, 2 monitors out with a switch.
I'll start looking more later.
Gotta go to Yoga before I explode on the people walking around like it's pre-pandemic...
Cosmic Puppet
This is what I want to do:
Just without the RGB being affected.
So I might try one of these before I think about sending this back. If I could get in the box I could just do away with the 5V USB but it's just glued or something.
Cosmic Puppet
Just read this again @Steve So you reckon the 5v leaking to the rgb will not occur if the switch is mechanical?Steve wrote: 21 Sep 2020 12:13 That's odd.. looks like the 5v is leaking into the r/g/b lines somehow. It is a digital switch and looking at the reviews on amazon there are many people having issues with it... I personally just use a simple mechanical switchbox for my TT's two outputs which works fine, & a more expensive Belkin powered KVM for my other machines, so I can certainly recommend Belkin (They are expensive new, but can be found dirt cheap on ebay usually, from old offices)
If it's mechanical there wouldn't be any issues. As it's just a physical switch. No residual current.
Cosmic Puppet
Okay, brill.Steve wrote: 21 Sep 2020 17:04 If it's mechanical there wouldn't be any issues. As it's just a physical switch. No residual current.
Although the only issue is the colour change. If the box had screws I'd just take out the power.
Thinking of trying this:
I think the OSSC might be getting 'round the picture quality issues people are having. At a tenner I'll try it.
PaulJ
Cannot see a picture or anything... just a large gap. same as post above.. :WTF:
Have you scoped your 5v supply for high ripple or other interference?
