Vertical lines in colour mode.
Cosmic Puppet
Post by Cosmic Puppet »
I've been wondering what the cause is for a while and I've had all the mandatory fixes done.
I was just doing some more checking comparing stuff and remembered this setting on the OSSC.
I'm wondering if this might give someone a clue as to the cause:
Could it be that my Atari is a US 60Hz machine?
Re: Vertical lines in colour mode.
What motherboard ?
Cosmic Puppet
exxos wrote: Sun Sep 20, 2020 8:12 pmWhat motherboard ?
STFM C070523-001 REV.D1
https://www.exxosforum.co.uk/forum/viewt ... =23&t=1162
You could try 47pf on the RGB lines on the socket..if they are not there already..
Cosmic Puppet
exxos wrote: Sun Sep 20, 2020 8:27 pm https://www.exxosforum.co.uk/forum/viewt ... =23&t=1162
Thanks @exxos
I'm not sure as I don't know what that looks like.
This is all the stuff I've had done currently:
https://www.exxosforum.co.uk/forum/viewt ... =18&t=3232
Are you sure that not just strobing/phase issue with the "modern" LCD display? Do you have a CRT you can try it upon?
Cosmic Puppet
stephen_usher wrote: Sun Sep 20, 2020 9:46 pm Are you sure that not just strobing/phase issue with the "modern" LCD display? Do you have a CRT you can try it upon?
It's identical on my Multisync monitor and on my PC monitor through the OSSC.
I did still have a High Resolution CRT monitor when I first got this Atari and the picture was inferior compared with my old ST which was the revision Exxos likes. It used to look crisp on the old ST, although I never saw it through a colour monitor. I only used it for Notator and didn't have this support network back then.
Cyprian
Post by Cyprian »
I have never observed a such lined yet.
What about recapping?
http://260ste.atari.org
Cosmic Puppet
Cyprian wrote: Sun Sep 20, 2020 10:09 pm I have never observed a such lined yet.
Had all this done:
Works perfectly (with the odd moment when I just have to turn it off and on again due to normal Atari behaviour :lol: )
Picture been poor from the start. High resolution is not bad, but the colour has always done this vertical thing.
I remember being disappointed when I tried it on my trust monitor and it looked poor. The monitor had always looked good.
It's not a deal breaker but it ruins demos like this that use lines:
Cosmic Puppet
@stephen_usher I've just asked that question here as it turns out to be typical of my board revision:
https://www.exxosforum.co.uk/forum/viewt ... 2&start=10
