Vertical lines in colour mode.
- Cosmic Puppet
I've been wondering what the cause is for a while and I've had all the mandatory fixes done.
I was just doing some more checking comparing stuff and remembered this setting on the OSSC.
I'm wondering if this might give someone a clue as to the cause:
Could it be that my Atari is a US 60Hz machine?
Re: Vertical lines in colour mode.
What motherboard ?
- Cosmic Puppet
STFM C070523-001 REV.D1
https://www.exxosforum.co.uk/forum/viewt ... =23&t=1162
You could try 47pf on the RGB lines on the socket..if they are not there already..
- Cosmic Puppet
Thanks @exxosexxos wrote: Sun Sep 20, 2020 8:27 pm https://www.exxosforum.co.uk/forum/viewt ... =23&t=1162
I'm not sure as I don't know what that looks like.
This is all the stuff I've had done currently:
https://www.exxosforum.co.uk/forum/viewt ... =18&t=3232
Are you sure that not just strobing/phase issue with the "modern" LCD display? Do you have a CRT you can try it upon?
- Cosmic Puppet
It's identical on my Multisync monitor and on my PC monitor through the OSSC.stephen_usher wrote: Sun Sep 20, 2020 9:46 pm Are you sure that not just strobing/phase issue with the "modern" LCD display? Do you have a CRT you can try it upon?
I did still have a High Resolution CRT monitor when I first got this Atari and the picture was inferior compared with my old ST which was the revision Exxos likes. It used to look crisp on the old ST, although I never saw it through a colour monitor. I only used it for Notator and didn't have this support network back then.
I have never observed a such lined yet.
What about recapping?
Atari V4sa / Lynx I / Mega ST 1 / 7800 / Portfolio / Lynx II / Jaguar / TT030 / Mega STe / 800 XL / 1040 STe / Falcon030 / 65 XE / 520 STm / SM146 / SM124 / SC1435
Antonia 2 / ATW800/2 / SidecarTridge / ACSI2STM / Mach64 VME / Mach32 VME / ET4000 VME / Atari 1050 / DDD HDD / AT Speed C16 / TF536 / SDrive / PAK68/3 / Lynx Multi Card / XCA12 / SkunkBoard / CosmosEx / SatanDisk / UltraSatan / USB Floppy Drive Emulator / Eiffel / SIO2PC / Crazy Dots / PAM Net
http://260ste.atari.org
- Cosmic Puppet
Had all this done:Cyprian wrote: Sun Sep 20, 2020 10:09 pm I have never observed a such lined yet.
Works perfectly (with the odd moment when I just have to turn it off and on again due to normal Atari behaviour
Picture been poor from the start. High resolution is not bad, but the colour has always done this vertical thing.
I remember being disappointed when I tried it on my trust monitor and it looked poor. The monitor had always looked good.
It's not a deal breaker but it ruins demos like this that use lines:
- Cosmic Puppet
@stephen_usher I've just asked that question here as it turns out to be typical of my board revision:
https://www.exxosforum.co.uk/forum/viewt ... 2&start=10
