WHDLoad 1111 Error
TF534 - 68030 + More RAM Board (More compatible with amiga hardware)
ninjafahrer
WHDLoad 1111 Error
Post by ninjafahrer »
Hi all,
I am getting an Error with basically everything I d like to run in WHDLoad (Error 1111) with my TF534.
Having a ROM 3.1 on a A500 Rev 6A board and MMULibs installed is there any hint you have for me?
PaulJ_2.0
Re: WHDLoad 1111 Error
Post by PaulJ_2.0 »
Turn on NoAutoVec in whdload.prefs in S Dir
Also make sure your max transfer is set to 0xFE00
matt020
Post by matt020 »
0xfe00 or 0x1fe00? All info I found points to 0x1fe00 .....
PaulJ_2.0
Post by PaulJ_2.0 »
Sorry typo, yes 0X1FE00.
supaduper
Post by supaduper »
Also try the switch `NOMMU` as mmu is know to cause problems with WHDload
ninjafahrer
tried both, no change :(
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
Try different CPU or lower cpu seed to 40Mhz
ninjafahrer
can I do that via jumper or do i need a new oscillator?
Return to “TF534 (OBSOLETE)”
Users browsing this forum: ClaudeBot, Google [Bot] and 2 guests
