Hi all,
I am getting an Error with basically everything I d like to run in WHDLoad (Error 1111) with my TF534.
Having a ROM 3.1 on a A500 Rev 6A board and MMULibs installed is there any hint you have for me?
WHDLoad 1111 Error
PaulJ_2.0
Re: WHDLoad 1111 Error
Turn on NoAutoVec in whdload.prefs in S Dir
Also make sure your max transfer is set to 0xFE00
matt020
0xfe00 or 0x1fe00? All info I found points to 0x1fe00 .....
supaduper
Also try the switch `NOMMU` as mmu is know to cause problems with WHDload
8 Bit Dreams
- Moderator Team
Try different CPU or lower cpu seed to 40Mhz
ninjafahrer
can I do that via jumper or do i need a new oscillator?
Users browsing this forum: Baidu [Spider], ClaudeBot, Google [Bot] and 2 guests
