Some notes on the box itself before talking about the problems. It has an ST keyboard (it seems) and even though the seller claims this is NTSC (and I am in US, I think it might be PAL. It says it's from GERMANY on the bottom. A friend thinks this is a PRE-PRODUCTION Falcon because it came (originally) with TOS 4.0.1 (the seller upgraded it to 4.0.4)
Problem 1: Keyboard stuck sounds and wrong characters printed
It seems like a bit of a frankensystem as well, with a painted ST keyboard (which does look nice) but sometimes produces the wrong keystrokes and makes those keystuck noises when I press on the case (which is slightly bulging on top. I know this has an Exxos Ram upgrade in it and maybe they didn't fit it in right or didn't put cardboard in there to protect the solder joints. I don't know yet.
Problem 2: Video is all messed up
RF
The video on this box doesn't seem to work correctly out of RF. Comes in as B&W. A lot of people on Facebook claim that despite what the seller claims *being ntsc* this is probably a PAL system and I need to reset the NVRAM? I haven't tried this yet because to put any software on this box I need to crack it open and pull the CF card (as I mentioned the floppy doesn't work)
VGA
I got a DB19 to VGA adapter from BEST electronics here in the states. I plugged it into a Samsung SyncMaster monitor's vga port and got a nice picture in 4 color mode only! If I try anything else it goes down hill quickly. See below.
Any help here guys would really be appreciated. I'm not a hardware guy (I write Java server code for a living) but I'm adept enough to get by and can do some basic soldering and use a multimeter if pressed.
Motherboard photos (just taken)
