New Falcon a lemon?
Gyrussfanx
New Falcon a lemon?
Post by Gyrussfanx »
My wife bought me a falcon off eBay for my birthday (first one I have ever owned! :D ) and well, I think it's a bit of a lemon. The floppy doesn't work (this was known to me before buying) and the seller said and took pictures of a only slightly distorted vga out. The box comes with an Exxos 14MB upgrade along with some other fixes. You can see the original Ebay description here: https://www.ebay.com/itm/Refurbished-At ... 7675.l2557
Some notes on the box itself before talking about the problems. It has an ST keyboard (it seems) and even though the seller claims this is NTSC (and I am in US, I think it might be PAL. It says it's from GERMANY on the bottom. A friend thinks this is a PRE-PRODUCTION Falcon because it came (originally) with TOS 4.0.1 (the seller upgraded it to 4.0.4)
Problem 1: Keyboard stuck sounds and wrong characters printed
It seems like a bit of a frankensystem as well, with a painted ST keyboard (which does look nice) but sometimes produces the wrong keystrokes and makes those keystuck noises when I press on the case (which is slightly bulging on top. I know this has an Exxos Ram upgrade in it and maybe they didn't fit it in right or didn't put cardboard in there to protect the solder joints. I don't know yet.
Problem 2: Video is all messed up
RF
The video on this box doesn't seem to work correctly out of RF. Comes in as B&W. A lot of people on Facebook claim that despite what the seller claims *being ntsc* this is probably a PAL system and I need to reset the NVRAM? I haven't tried this yet because to put any software on this box I need to crack it open and pull the CF card (as I mentioned the floppy doesn't work)
black and white RF out
VGA
I got a DB19 to VGA adapter from BEST electronics here in the states. I plugged it into a Samsung SyncMaster monitor's vga port and got a nice picture in 4 color mode only! If I try anything else it goes down hill quickly. See below.
simple adapter setup
this actually looks right/good
16 color 80 column with weird black blurred menu
truecolor 40 column with weird black blurred menu
Any help here guys would really be appreciated. I'm not a hardware guy (I write Java server code for a living) but I'm adept enough to get by and can do some basic soldering and use a multimeter if pressed. :)
Motherboard photos (just taken)
floppy 1
floppy 1
floppy 2
floppy 2
under the psu
under the psu
motherboard cf reader
motherboard top left with psu
motherboard top right center
motherboard bottom left
motherboard bottom right
exxos 14mb simm
exxos 14mb simm
simon.osborne
Re: New Falcon a lemon?
Post by simon.osborne »
I haven't owned a Falcon for a very long time, but there's a program called BOOTCONF that can be used to set the NVRAM for your region. May be worth trying: https://milan.kovac.cc/atari/software/?folder=/SYSTEM
Exxos has some programs also on this page https://www.exxosforum.co.uk/atari/last/NVRAM/index.htm
I 'think' you can still save the settings if the NVRAM battery is dead as that is just for the real time clock. But like I said, it's been so long since I had a Falcon I'm just going off memory.
Gyrussfanx
Yeah. I’m gonna have to crack it open to install it but I’ll give it a try.
Please do try saving the nvram with correct perimeters, while the case is open can you take some nice high res screenshots for us of the board? The images from facebook are too blurry, but I did notice there was a socketed pll ic chip under the PSU which isn't on Falcons I've seen before.
Gyrussfanx
I added all the mb images to the original post (including under the PSU)
DoG
Post by DoG »
Steve wrote: Sat Jul 25, 2020 4:04 pm... The images from facebook are too blurry, but I did notice there was a socketed pll ic chip under the PSU which isn't on Falcons I've seen before.
It's for a 68881/68882. FPU.
Atarian Computing
Post by Atarian Computing »
Taking a stab at the date of manufacture. @mikro has a great source here: https://mikrosk.github.io/clockpatch/history.html
Yours seems to be a PAL-B machine if I'm reading the code correctly. It does seem to indicate CA401332-003, which would make it ASSY PCB FALCON030 PAL-B (UK, generally UK, Ireland, Hong Kong, South Africa, and Macau; last Atari revision: H).
Your serial # begins with Y42 so not the earliest revisions, which would have had B5/B3.
Gyrussfanx
yeah, It says GERMANY on the bottom and also has the original SPEC of 50mhz. The board being even more different than that (given the painted keyboard). It's been changed and now I guess I need to reset the video to deal with NTSC?
The CF doesn't seem to be dos formatted and my pc cannot read it. Huge problem since the floppy on the Falcon isn't working. I have no idea how to get that done on my PC. I do have a copy of petri's 8-bit-chip HD driver partitioner for the ultra satan and it comes with an image that I might be able to write to CF. It's generally meant for an SD so I am not sure that this will work. Too bad the ultrasatan cannot be used here as it is asci not ide or scsci.
Without being able to write to this card I cannot put any diagnostic tools in.
Ideas?
troed
Post by troed »
Someone has definitely cared for this Falcon before - the built in fan is replaced with a low noise Noctua. Can't see if NVRAM has been changed though.
The image issue is indeed weird. Do you have another monitor as well?
/Troed
Gyrussfanx
I have a view sonic I can try.
UPDATE: The view sonic couldn't cope at all. Not sure it's multisync.
