I need your help for my Falcon030
silversword31
Re: I need your help for my Falcon030
Okay, I'm still checking the problem. when I remove the ram card, the values obtained at cpu init are the same: ssp =$0E2040 and PC=$217900000. So I've removed the rom chip and the processor does not gotten anything ... The chip select is correctly made by Combel... So my problem is "maybe" the rom chip ... I need a new
Could the problem be with one of the GAL's?
silversword31
I've maybe some problems with GAL but, now, values received from the rom are never good even in transitory states. So I think my first problem is the rom chip, but it might not be the last...
silversword31
My order is placed on Exxos Store
Now, i have to wait...
silversword31
Hi folks,
I changed the Rom: still nothing.
I reprogram all the GALs: still nothing
I check the data and address continuity between CPU and ROM : All ok.
Have you an idea ? I'm lost
Just a couple of things I'm wondering... (sorry if you've already answered these)
* have you owned this Falcon for a while & it used to work? In what circumstance did it stop working
* Is there any board modifications at all? ie; clock patches, nvram, boosters
No, no it's not. The expansion bus is actually a very bad place to test the CPU, unfortunately. It's translated and not fully.silversword31 wrote: Fri Jul 10, 2020 7:09 am Hi,
i've another capture on cold start (tigger on vcc). I don't understand how i can have cpu activity without clock... Is the expansion bus directly connected on 68030 ?
Which explains this. You'll only see DTACKs during DMA.silversword31 wrote: Sat Jul 18, 2020 7:01 pm I've done another capture. I don't understand why the first action of cpu is to write $FFFF. Another curious thing is that /DTACK is totally inactive...
Looking at your snapshot of the start-up sequence:
You can see the CPU looks good -- it asks for the correct two longwords (four 16 bit accesses). The reply to the first two accesses should be 00E0, 0030. This will result in E00030 being the next access. It's not, it's 780000. That's wrong.
So it looks like you're not getting the results from ROM.
That could be caused by COMBEL not decoding the ROM address, but it is issuing a DSACK1 and in another post you see a bus error, so I'd be inclined to think COMBEL is decoding ok.
It could be COMBEL isn't asserting /XROM2, but you've tested that.
It could be the ROM? You've replaced that, but what about its socket? Is the chip getting power, perhaps?
It could be the data lines? Continuity's not enough. We can check it better: remove the ROM chip again. You should be getting FFFF on the data line from the pull-ups. That startup sequence above should therefore try to access FFFFFFFF on the fifth cycle.
This would seem the next step to me. If something's pulling the lines low, or talking on the data bus, you might be seeing this kind of thing.
Good luck,
BW.
silversword31
Thanks a lot for your help
I’ll try to remove rom and watch the result. I’ll give you the result. Thanks
silversword31
When i remove the rom, i get $FFFF as Data. It's good. But, now, the cpu doesn't continue after reading $000004.... It stops after reading
