I'm new in this forum and i need your help to repair my Falcon030. My falcon don't boot with the wellknown black screen and garbage graphic artefact. I own a 34ch usb logic analyzer and i've made some capture. The cpu meets a double bus error on bad memory access. On the capture, i can see the double bus error :
The CPU init seems to be correct:
But on the following capture, i can see that the reading of data is inconsistant. The data values change during access (don't worry about 100ns capture rate, the result is the same with 8ns rate):
I think that the problem is the Combel. What do you think ?
Thanks for your help
