ALPS DF354N floppy cable - Atari Falcon
Re: ALPS DF354N floppy cable - Atari Falcon
ap_kelly wrote: 15 Jul 2020 14:33 Found it :-)
I have the C302096-001A
Thanks for the info.
No problem
ap_kelly
Post by ap_kelly »
@rubber_jonnie I don't suppose you know which chip in the Falcon relates to this fix as well?
https://www.exxosforum.co.uk/forum/viewt ... =17&t=1395
My resistors for both fixes 3&4 have arrived now (just waiting on my recent PSU capacitors order now), I just need to get brave and give it a go, though if I get stuck the members of the local Sydney Amiga Users Group have offered to help me out. They have some professional electrical engineers as members, and have restored lots of other machines.
Current: Atari 2600, Atari Falcon 030, Apple MacBook Pro
Previous: Sinclair ZX 81, Atari 520 STFM, Atari 1040 STE
Google Developer Expert for Android
I have just updated the topic for the Falcon.
ap_kelly
Post by ap_kelly »
Excellent.....although that U35 chip is terribly small....I might need a smaller tip for my soldering iron.
Are you able to update the page for the bussed 10k resister to highlight where the "raised leg" connects to on the Falcon.
Thanks.
ap_kelly wrote: 17 Jul 2020 15:12 Excellent.....although that U35 chip is terribly small....I might need a smaller tip for my soldering iron.
Thanks.
It's a 74LS06
Ah it might be a smt chip on the falcon, ive not checked.. AFAIK nobody has done the falcon mod yet.. I guess you could just solder the resistors on the back of the floppy connector instead...
exxos wrote: 17 Jul 2020 15:23 Ah it might be a smt chip on the falcon, ive not checked.. AFAIK nobody has done the falcon mod yet.. I guess you could just solder the resistors on the back of the floppy connector instead...
Ahh, I looked at the linked topic and assumed. If it's tiny you might be right and it's SMT.
ap_kelly
Post by ap_kelly »
So this is what I'm staring at, you can see the U35 socket at the bottom. The bussed 10k resistor held in place with bluetak prior to soldering.
DoG
Post by DoG »
Pin 6, 8 and 10 have visable vias close by. So maybe easier to use them? Pin 2 I can't see on the pic where it goes but I'm sure it also have a via somewhere. Measure that.
5V on pin 14 also has a via.
ap_kelly
Post by ap_kelly »
Here is a better photo, if I can use those little holes instead of soldering on the legs of the chip, that'd probably be a lot easier.
