TF536 Rev 2 Design Complete (all gone)
68030 + SDRAM + IDE
Re: TF536 Rev 2 Design Complete (all gone)
8 Bit Dreams wrote: 01 May 2020 11:37 Ok here is my update:
done like Stephen said (lifted Pin1 and connected it to Pin2) - card is fully working now!
Thumbs up!🖒🖒
Excellent. This will be in the next batch.
EDIT: tell me how it performs on long cables.. although I've never understood the need to have your hard disk in your neighbours house etc
8 Bit Dreams
Moderator Team
Moderator Team
Post by 8 Bit Dreams »
:mrgreen: :mrgreen: :mrgreen:
ok, tested 30cm long cable - no problems here, works flawlessly, my A2000 will love it! 🤗☺
Ready to order 20 pcbs immediately
agranlund
Post by agranlund »
:dualthumbup:
Great news, glad to see that's all easily sorted.
I've probably got use for 5 or so boards when you are ready @terriblefire
8 Bit Dreams
Moderator Team
Moderator Team
Subzero79 wrote: 01 May 2020 11:43 u removed all rns underside the ide and polulate ics? plus lift pin 1 and tie to high
Yes, RN6-RN10 must be removed if You decide to build card with buffers
Really just waiting for @LADmachining and @alenppc to confirm working.
LADmachining
Post by LADmachining »
terriblefire wrote: 01 May 2020 15:31 Really just waiting for @LADmachining and @alenppc to confirm working.
Hi Stephen,
My board is working OK as long as I disable caches via the early-startup menu or using the CDIS jumper, otherwise the machine gurus as workbench loads.
When booting with caches disabled in the early-startup menu, enabling IBurst in Sysinfo or AIBB gives an instant guru.
Have tried it with different CPUs, in different machines, and have reflowed CPLD twice. Any other suggestions of areas I should check please?
Works absolutely fine otherwise, had it looping demos and games for approx 24hrs
LADmachining wrote: 01 May 2020 16:13 Hi Stephen,
Ok so i'd say this is not working at all.
Is this WB 3.1? It wont work on lower versions. I would look at the STERM pin. Its very strange as i've not seen this issue before.
LADmachining
terriblefire wrote: 01 May 2020 16:22
It is WB3.1, same install/CF card is working fine with TF534s with regards to caches.
Will look into the STERM pin and associated circuit. Would it be possible to have a boardview file for this board?
Thanks,
Anthony
alenppc
Moderator Team
Moderator Team
Post by alenppc »
My board hasn't arrived yet...
Return to “TF536”
