Thank you for correcting! Didn’t remember it was labeled ESPHEADER.Careful! The TF3xx's do not have SPI ports. Those are only on the TF5xx series.
Getting WFI Working on TF3xx with ESP Module
theq
Re: Drivers for ESP modules
kulamario
If I do simple converter like this is should work ?
- Admin sponsor
That circuit will kill the ESP module. It needs to convert down to 3.3V (Your circuit looks like its 5V).
kulamario
My module have voltage regulator
- Admin sponsor
The TX and RX pins are not 5V tolerant!!!!!!
kulamario
Can u give some solutions?
How should be done please
Maybe is enough to use some like this?
https://www.ebay.co.uk/itm/173946979598
theq
The ESPHEADER on the TF330 is already 3.3V so you don’t need the MAX232. You only use those on the old school 9- or 25-pin serial ports.
You can use your ESP32-device, but it will not look so nice ;)
kulamario
I no have TF330
I want connect internet WiFi to my Amiga 500 via parallel port
- Admin sponsor
One of those which supports 3.3v will work.kulamario wrote: 08 Apr 2020 12:56 Can u give some solutions?
kulamario
Thanks Terriblefire I order this module
Users browsing this forum: ClaudeBot, Qwantbot and 3 guests
