Getting WFI Working on TF3xx with ESP Module
theq
Re: Drivers for ESP modules
Post by theq »
Careful! The TF3xx's do not have SPI ports. Those are only on the TF5xx series.
Thank you for correcting! Didn’t remember it was labeled ESPHEADER.
kulamario
Post by kulamario »
If I do simple converter like this is should work ?
That circuit will kill the ESP module. It needs to convert down to 3.3V (Your circuit looks like its 5V).
kulamario
Post by kulamario »
My module have voltage regulator
The TX and RX pins are not 5V tolerant!!!!!!
kulamario
Post by kulamario »
Can u give some solutions?
How should be done please
Maybe is enough to use some like this?
https://www.ebay.co.uk/itm/173946979598
theq
Post by theq »
The ESPHEADER on the TF330 is already 3.3V so you don’t need the MAX232. You only use those on the old school 9- or 25-pin serial ports.
You can use your ESP32-device, but it will not look so nice ;)
kulamario
Post by kulamario »
I no have TF330
I want connect internet WiFi to my Amiga 500 via parallel port
kulamario wrote: 08 Apr 2020 12:56 Can u give some solutions?
One of those which supports 3.3v will work.
kulamario
Post by kulamario »
Thanks Terriblefire I order this module
